Question about Dream Maker Spas Pool & Spa
Replaced backlight lamps on a Coleman Horizon 411 Spa topside controller, multiconductor flat cable to RJ45 connector conductors had insulation disintegrate at connector on Topside controller PC Board
Powered down spa to replace backlight lamps on topside controller. Had to remove the back cover to access and clean corrosion from the backlight lamp socket connections. Insulation on connectors that was exposed to the atmosphere disintegrated when touched, leaving nothing but bare copper wire strands. Wires literally fell out of connector on PC Board but insulation trapped in the clear conformal coating revealed exactly where each conductor was landed. Redressing the wires, cleaning up the PC Board header where the wires were landed then reconnecting the wires resulted in the backlights working but the control buttons not and no display was visible any longer. Cycling the power off for several minutes and then back on doesn't help. The spa automatically goes into default two hour circulate/heat/clean mode and the remote dual pump control pad works fine. Is there a way to test/reset this main topside controller? Is there a color code lead connection wiring diagram available for the flat cable to the RJ45 connector? Any help would be appreciated.
2 Suggested Answers
uspartscente
  • 717 Answers
SOURCE: hot tub jets won't come on. Backlight on topside works and shows current temp. but jets or led lights in tub won't work. Topside panel buttons are dead. What is problem? Viking Royale spa
This sounds like a back circuit board to us.
rod
uspartscenter.com
Posted on Apr 09, 2013
I have a Coleman spa that works fine for about 15 minutes or so and then. The one pump stops and starts to surge on and off .the switch won't let me turn it off or on I've burned up one pump because
Do you have an auxiliary remote control panel?
Is it plugged into the cable of the main control topside panel?
If you do you have a remote panel, and it is not plugged into its own receptacle on the circuitboard, but onto the cable of the main top side panel, that remote panel may have a short. As it would override the ability for proper operation at the main panel. Disconnect that remote panel, it will not lessen the ability of spa operation, other than the convenience factor of having a remote panel, it should repair your problem.
Apr 08, 2015 | Pool & Spa
I have a vita duet spa. It has a pb error and the jets or the lights will not turn on. Any suggestions?
Vita Spa Error code (PB) is a power board communication error. Turn off the power and then check the connection between the topside control and control box. check for loose or unplugged wires, unplug the topside control (after turning off the power) and check for signs of shorts or charring on the wiring ribbon/connectors. If you cannot find the source of the problem you will need to contact your dealer or repair technician. I hope this helps =)
Nov 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Coleman Hot Tub Model 411
This spa was manufactured by Maax. Try Maaxspas.com for your owners manual.
Nov 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
When the pc starts up, the lcd switches on and off and flickers. Why is it doing this?
Old CCFL lamp or lamps (backlight), or damaged insulation of high-voltage wires from inverter to lamps. Unplug flat cable coming from display to processor board to observe better the flickering. Next, using 27pf 3kV capacitor as substitution of single lamp - unplug lamps one by one, solder that capacitor to the connector pads instead - localize the faulty lamp. You may keep that capacitor there permanently or replace faulty lamps. You can by them on ebay for instance.
Sep 11, 2009 | HP Compaq FP5315 15" LCD Monitor
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Need owners manual for coleman spa 208 or 408
Go here and print it out. Nancy
team.maaxspas.com/manuals/horizon%20series%202000.pdf
Dec 19, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Pool & Spa Logo
108 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
