Question about GE Washing Machines
Ge profile hydrosoft leaking from bottom washing machine diagram
futureloginn
  • 734 Answers
SOURCE: My Ge washing machine is leaking from the Bottom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
  • 1314 Answers
SOURCE: WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
Posted on Jan 18, 2008
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
SOURCE: ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Posted on Apr 10, 2009
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
How to take the back off GE Profile washing machine
take off the bottom on the front, then pull the drum. cant take the back off.
Oct 08, 2012 | GE Profile WPRE6150K Top Load Washer
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Leaking oil from the bottom of the machine
Hi, Your problem is quite terminal, but easy to fix. You will need to replace the gearbox in the machine will cost around £150.00.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
Washer Leak on GE Profile WPSR3120
That is an 7-10 year old model. Buy a new one. You're probably talking about major seal leaks which are gonna cost you a lot of time and money to repair.
Oct 18, 2008 | GE Profile WPSR3120WWW
GE Profile stackable washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 29, 2008 | GE Profile WPXH214F
Jan 18, 2008 | GE Profile Performance WPSF4170WAA
Washing Machines Logo
701 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
