Question about Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
One breaker is popping what to do
What to do when just one breaker keeps popping when trying to turn on
    Sergeant:
    Champion:
  • 203 Answers
You have a wiring problem on that circuit. The circuit is doing it's job. Call a qualified electrician.
Posted on Feb 04, 2015
Keeps blowing circuit breaker
It could be the circuit breaker, those do sometimes go bad, but it could certainly be something plugged into that circuit pulling more current than it should. Try disconnecting everything on that circuit. Does the breaker still pop? No? Plug one thing in. Pop? If not, keep going until you find the one that's a problem, and check the total amount of current all the devices you have plugged in use.
Most standard plug circuits are only rated at 15 amps. For example, a toaster may pull 12, a hair dryer 10. You can't run both at the same time on one circuit.
Jul 10, 2015 | Electrical Supplies
My catalina spa keeps popping the breaker and won't turn on
First, we have to establish what you mean by turn on the unit. Is the GFCI breaker set on when you try to turn the "unit" on? What are you activating to turn the "unit" on? A switch, a disconnect, a button on the topside controller, etc.? Need clarification before we proceed to diagnose. At what level do you understand electricity? Is there a licensed electrician available?
Please answer and we will take it from there. OK?
Jul 14, 2014 | Balboa Instruments Duplex Digital Panel 2...
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
I have changed out the batteries and hand control on my Jazzy 1103 Ultra.but now the circuit breaker keeps tripping. Dee
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
Jan 31, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Breaker on motor keeps popping off ///cools down,powers up=but blows out again====replaced motor and checked water pump if clogged ok.
You need to try turning the parts by hand that the motor is supposed to be turning. The breaker is popping because of a mechanical overload--probably within the transmission itself. Check drum rotation as well as the agitator for high resistance. Good luck!
Sep 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Keep poping the breaker on instllation
Check your wiring for short circuits. If you turn the switch on and it pops it may be in the switch box or up in the fan box. Also make sure the fan blades spin freely. A motor overload or short circuit would be the only reason for the breaker tripping immediately.
Jan 10, 2010 | Hunter Sontera 52" Ceiling Fan with...
Loud pop, now circut breaker flips off when I turn on the machine
HI
A loud pop can be a couple of things. Usually it is a ruptured hose, or a hose the has separated from its keeper.. This can explain why it is you are popping the circuit breaker. Water is spraying on an electrical circuit, and causing the short. The other thing that pops is when you blow the circuit board but then you would have a burnt smell.
Oct 14, 2009 | Starbucks Saeco Italia Digital Barista...
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Breaker Keeps Popping
there is something wrong inside the saw.
if you are trying different amperage breakers ( trying a 15 AMP breaker and then trying a 20 AMP breaker) or if you are trying all 15 amp breakers try a 20 AMP
Jun 28, 2009 | Mk Diamond Benchtop Wet Tile Saw
Compressor tries to keep running pops the breaker
Inside the control unit is a spirally spring like diapragm, it holds a ball bearing that should shut off the compresor at max pressure. The ball bearing has probably fallen inside the tank. Now it won't shut off so it tries to keep runniong. The back pressure cause an overload on the compressor motor and so blows the breaker. You need a bigger ball bearing or a replacement diaphragm. However you cannot get parts as there is a safety recall see this site: http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Apr 02, 2009 | Craftsman Air Tools & Compressors
Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED Logo
208 people viewed this question
Top Hilltop Rv Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Hilltop Rv Electrical Supply Expert? Answer questions, earn points and help others
