Question about Disney C1310atv 13-inch Tv Tuner/receiver - Red
C1310atv shuts off - Disney C1310atv 13-inch Tv Tuner/receiver - Red
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
Need replacement remote for model #c1310atv TV
Hello
Just buy one universal remote control, which have setup codes for your tV. If there is setup code, you can see it on attached code list.
Mar 06, 2012 | Televison & Video
Who manufactures the cars tv model number c1310atv need to find remote code for universal remote , and which brand would work best for this tv
Unknown small company make this tv for the Disney Corporation.But u can buy the original remote for this tv.Try website like Remotes.com to buy an original remote.
Nov 07, 2010 | Disney DTD1363-CAR 13" TV/DVD
Whomanufactures the cars tv model number c1310atv
Some Unkown company Disney contracted,no universal code.Must buy exact remote or compatible one.Try this website have it.1-800-Remotes Factory Original.
Oct 03, 2009 | Disney DTD1363-CAR 13" TV/DVD
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Oct 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
Missing remote control for c1310atv disney pixar cars tv/vhs
Philips Magnavox makes the remote. Not sure about the model #, but you can get to the audio/video or DVD by scrolling through using the channel buttons on the unit itself. I have also been successful with a universal remote with the exception the channel up and down would not fuction correctly, but direct entry did, as well as the source select. Hope this helps.
Oct 25, 2008 | Disney DTD1363-CAR 13" TV/DVD
Cannot get dvd to play on tv, no picture, try different channels, etc.,
on you tv must be a button "video/tv",you have to push this many times to find front, back or video1 or video2 (depent were you plug the dvd)and there is were supost to work. no on channel 3 or 4
Oct 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Cars tv and ps2
I have a lightning mcqueen 13' tv model# C1310ATV, and a little purple car-DVD player model # C8000 for my grandson, I cannot get dvd to play on tv? Should I hook it up(dvd) to back of tv or the front of tv, and if so, is there a switch over button for dvd to normal tv watching. TV is hooked up to Direct tv and plays fine. But can't get dvd to play on tv, I've tryed channels 2, 3, and 4. But no picture. Again is there a switch over button or auxiliary button or ???
Your help and consideration, concerning this problem will be greatly appreciated by my grandson and myself. Thanks
Mar 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
Disney C1310atv 13-inch Tv Tuner/receiver - Red Logo
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
