Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
Lawn chief 5 hp tiller not getting gas will start if primed with gas or using starter fluid but stalls out
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: my 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Posted on Aug 16, 2009
Mantis tiller won't start
Flush out old gas. Check/clean spark plug. Oil filled? Try spraying starter fluid in carb. Carb should not have any oil in it. Change air filter.
Jun 04, 2015 | Mantis Tiller Honda 4 Cycle - No Kickstand...
How do you start it/
Check:
- Gas in gas tank
- Oil level correct.
- Tiller drive in off/disengaged position.
Start procedure:
- Fuel selector - ON
- Ignition switch - On
- Choke - On
- Throttle position - Slow
- SAFETY - No children within 10 feet/
Pull Starter rope......
Repeat 3 - 5 times only.
If engine starts, release choke as required until engine runs smoothly.
If no start,
- set Choke to OFF, Throttle to FULL,
- pull starter rope 3 - 5 times only.
- if start, reduce throttle to obtain smooth idle
- if No start, start check for:
- Spark at plug
- Fuel in the jug
May 22, 2015 | Garden
Engin runs fine at idle but stalls out at high idle and wont rev up.
Hi 5flash... Get an assistant and a can of starter fluid. Remove the air cleaner and spray some starter fluid into the air intake. Start it up and spray the starter fluid as you move it to high idle, repeat until it works properly. Joe
Thanks for choosing Fixya!
Feb 22, 2011 | Mantis 2-Cycle Tiller
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
I have fuel and a good spark, but will not start with out spraying starter fluid into carb.
sounds like your carburetor is plugged, or has lost its prime. As I need to know more, please state the brand of engine it has; briggs or tecumseh, and if briggs, is it a quantum (5 hp or greater with carb not attached to gas tank) or regular?(has the carburetor on top of the gas tank.)
Mar 29, 2010 | Garden
4 hp brigs engine on merry tiller sitting around for 2 years and won't run, but will start with starter fluid.
change out the gas in the tank. make sure fuel line from tank to carb is clear. if this is all good then you might need to clean and rebuild your carb, if you are not getting fuel through the carb to the engine.
definately a fuel issue.
Feb 28, 2010 | Garden
Tiller wont get fuel to start
Try disconnecting the line at the carb. Then carefully blow back to the tank. It may have something blocking the outet from the tank. If that doesn't do the trick, the float may be stuck and not allowing the needle to open for fuel to enter the carb bowl. Good luck...Lee
Aug 05, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Apr 06, 2009 | Maxim Garden
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
