Question about LG WD-1080FD Front Load Washer
Lg Front loading washing machine
LG WD-8013F Not drainging water, I have taken off the front cover and emptied the filter, there where a few coins, but nothing else, the water was a dark colour. I then ran the 'pump' cycle again to see if this made any difference, but none. There is no burning smell or anything like that when it attempts to pump, and there is a little 'spinning wheel' inside that is still spinning around when its attempting to drain.... PLEASE HELP!!!!!!!!!!
  • Anonymous Nov 22, 2008
    My husband left a wad of tissues in his pocket, and a toothpick. I missed it when preparing the load. There was lint from it still in the drum after the load was completely washed. I wanted to clean out the filter, but couldn't figure it out from the LG instruction book. These instructions were clear, worked perfectly, and now I can understand the book. Thank you.
  • 159 Answers
Most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Posted on Aug 04, 2007
I had the same problem and found a button jammed in the outlet hose where it attaches to the drain under the adjacent sink.
Posted on Oct 24, 2007
  • 641 Answers
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck!
I have LG Washing Machine and the water does not drain whilst the machine is washing. What can be wrong?
problem is with main board MOSFET ,FET or Transistor , that are not switching your drain pump at right time , if your'e pump is fine, , you should check drain pump separately by giving it separate supply. ( see its data sheet for power )
Dec 22, 2014 | LG Washing Machines
Lg 7.5 WD-8013F had sparks and stopped working
Where do sparks come from. Motor is in back.
Mar 10, 2017 | LG WD-80130F
My lg front load washing machine is reading oe
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
May 20, 2010 | Washing Machines
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
LG WD-1080FD Front Load Washer Logo
690 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
