Question about Konica Minolta Office Equipment & Supplies
I'm getting a code 200 and my machine stops
My paper runs fine out of the paper tray. But when it reaches the part where all of the toners/parts/heater etc, it stops at about the first set of rollers going into the main frame where all of the toner/parts/heater etc is at. Then my top panel is telling me C200 code.
  • Konica Minolta Master
  • 1,297 Answers
Charge corona cleaning motor error,try reset this code open and close the front door,or push the reset(trouble) switch.
Posted on Aug 05, 2009
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Code c0910
This error code means there is a paper lifting problem in the paper trays. Most common cause is improperly loaded paper. Check the trays to be sure all paper is loaded properly then turn off then back on, the MAIN power switch Not the one up on the control panel. If the code does not come back then your fine. If it does then pull out all of the paper drawers, reset the code again and then close each drawer one at a time waiting 15 seconds between each tray closing. If you close a drawer and it pops the code after a few seconds then that is the tray that is causing the problem. Double check that tray and if you can not get it to work then you will need service on that tray as it has a paper lift problem. Either the lift motor or the sensor. You can leave that tray popped open an inch or two and still use the copier with the other trays.
Good Luck and Thank You using Fixya.
Sep 22, 2010 | NEC IT2520 Fax
13 Printer Jam Problem
If it is jamming under the toner (meaning the paper is not quite reaching the toner cartridge, and "crinkling" up), then you would be correct. There may be a tiny pipce or chunk of paper creating a "well" and stopping the paper. If you remove the paper tray and the cartridge, and flip the machine on it's back (fuser side), you may be able to see the chunk in the paper path. You could also get a sturdy pice of laminated paper or card stock, at least an inch or two wide, and run it backwards thru the path to try to back out the chunk.
If the paper is just stopping, in any other spot than the paper tray, it could be a dirty or dead sensor. Try removing the cartridge and spraying canned air throughout the machine.
Apr 21, 2010 | HP LaserJet 4 plus Printer
My Pc745 has stopped pulling paper from the tray without crunching it up
try to run paper from the side bypass tray. if still no go, you may have something blocking the paper from feeding. if it feed from the side bypass but not the cassette, paper feed tire may not be feeding paper or the out of paper sensor maybe keeping paper from reaching paper feed tire
Apr 11, 2010 | Canon Office Equipment & Supplies
How do you stop the headed paper in the by pass tray being used when the plain paper in the main tray has run out? I have wasted so much headed paper by the machine switching without any warning.
the device is programmed at the factory as a default to switch. try two things,1st function, general, key operator, code 0000, then at number 1(paper size) select bypass and then change media to letterhead or something other than plain.
2nd, function, general, key operator, code 0000, then at number 4 ( special paper tray 1) designate the bypass as a special tray. this should "exclude" the tray from available tray. good luck
Apr 07, 2010 | Panasonic WORKiO DP-C262 Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Xerox 6100 laser - paper jams if paper tray low on paper
There could be two things. First, be sure the paper tray is not binding. The metal plate in the middle should spring up easily. The friction pad should be firmly attached to the tray, but not extending over the metal portion. The second thing would be to clean or replace the feed rollers. They are inside the machine above where the tray would sit. Since the tray feeds when full, I don't think you have a clutch problem. Let me know how it goes.
Jun 10, 2008 | Xerox 6100/DN Laser Printer
Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
61 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
