Question about Leica M6 TTL .58 35mm SLR Camera
Shutter release button sticks
The shutter release button on my leica M6 gets stuck after 4 or 5 frames. although it only gets stuck when film is loaded, I'm sure the film is loaded correctly.
2 Suggested Answers
  • 36 Answers
SOURCE: leica m6 film stuck, I think
Did you mean you wanted to unload the unfinished film?
What you did then? be more clear and specific about the procedures before I can give you suggestions.
pc-cook
Posted on Jan 26, 2008
Shutter button on Leica M4 doesn't work
Is there film in the camera, if so rewind the film and then test the empty camera, if your problem persists, service the camera.
Nov 24, 2013 | Leica M4 35mm SLR Camera
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
Film advance shows double exposures and spacing problems. What is the problem?
The film advance mechanism is broken.
Given the very high value of your camera it's definitely not a DIY repair. Although a professional repair will not be cheap, it will definitely make economic sense compared to the cost of replacing your M6, so send it to your nearest official Leica servicing agent.
Oct 15, 2010 | Leica M6 TTL .58 35mm Rangefinder Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Olympus OM-4 Shutter Release Button Stuck
  1. First ry to reset the Self Timer lever.
  2. Try to change the aperture.
  3. Try to unscrew the lens
  4. Open the film chamber slightly (just to loosen any lever that has got stuck)
One of these operations would dislodge any normal lever jam. If these fail to solve the problem, take it to a repair shop.
Jan 26, 2009 | Photography
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Leica m6 film stuck, I think
pc-cook
Oct 22, 2007 | Leica M6 TTL .58 35mm Rangefinder Camera
Leica M6 TTL .58 35mm SLR Camera Logo
124 people viewed this question
Top Leica Photography Experts
Tony
Wayne Tolonen
TC CAMERA REPAIR.Com...
Are you a Leica Photography Expert? Answer questions, earn points and help others
