Question about Shure Audio Players & Recorders
Replace antena - Shure Audio Players & Recorders
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact Shure for replacement parts.
Posted on Jul 27, 2014
I have a CRAIG 13 INCH HIGH DEFINITION LCD TV MODEL #CLC503 I PURCAHSED AT CVS / PHARMACY I GET CBS AND ABC STATIONS GREAT BUT I CANT GET NBC??????? PLEASE ADVISE OF THIS ISSUE
NBC antena broadcasting signal is weak and it sit in pretty low ranges on the mountains tops call mountain Wilson.The broadcasting antena is weak and ur receiving antena is weak too.Tries websites like Amazon.com Ebay.com to buy a Digital antena and used it,will boot up ur tv antena receiving signal stronger and longer ranges.Than.U will able to get the NBC tv channel.
Dec 03, 2010 | Televison & Video
Moisture in antena
Hello there.
Please click here to find a replacement antennae for your Humminbird device.
Hope this helps.
Jun 05, 2008 | Humminbird NS25 GPS Receiver
Power antena after markit how to make it work with radio
on the radio there is a cable that is for Power Antena you might have to set a cable out to the area you are instslling the antena if this car already had a power antena you only need to hook up the leds from the old if not then like i said you need to get positive cable out to the antena and ground it to chassis
Apr 01, 2010 | 2000 Mercury Sable
The antena on my 2005 chev silverado broke off at the base. Is the stud removable or do I have to replace the whole base?
You will have to replace the whole base along with the antena wire that goes into the cab. ON the base you will need to remove the retaining nut. The base will fall into the fender well. You will need to find the antena wire with in the cab, disconnect and reove it with the base. When installing the new antena you will need to put the antena through the fender well and tighten the retaingin nut. Feed the wire back through the are where the old was and reconnect. Good Luck. Please rate.
Mar 08, 2010 | OEM Systems Car Audio & Video
My sirius satellite radio stopped working antenae not found
my sirius satellite radio stopped working the screen states antenae not found in the car and at home on the boom box the antenae has been checked and is not the problem can this be fixed ?
Jan 29, 2010 | Sirius Satellite Radio Audio Players &...
1985 ZX300 power antena problem. When the radio is turned on the antena goes down and when it is shut off the antena goes up. Al factory parts, radio, antena and all switches. Any ideas what would cause...
im guessing the antenna has been replaced and wires were mixed up. take the rear panel off in the trunk to give access to the antenna motor and look at the wiring there should be 2 small wires and one larger black wire. the black wire is the reception wire the other two are the power wires. switch the positions on the two power wires. say wire A is in plug 1 and wire B is in plug 2. final position should be A in 2 and B in 1. that should take care of it. good luck
Jul 08, 2009 | 1985 Nissan 300ZX
No network
DEAR,CHECK WHETHER UR ANTENA SWITCH IS WORKING OR NOT,IF ITS FAULTY THEN CREATE JUMPERS OR REPLACE THE ANTENA SWITCH AND IF IT IS WORKING THEN CHECK NETWORK IC OR TRY TO FLASH UR PHONE
Jul 04, 2009 | Nokia 5310 Cellular Phone
No radio reception
MIght be an antena problem. Cheapest a quickest way to find out if the problem, your local autoparts store will sell a cheap replacement antena. Pull out stereo use this antena to check if more stations are picked up or use speaker wire about a foot or so in lenght and stick the wire in the antena port of the radio and see if you pick up stations, if so then your antena needs replacing.
May 16, 2009 | Car Audio & Video
Tv says no signal being received
check your cable or antena system
if its ok then chek the antena(RF socket).
for brocken or loose contact,
if thats also ok
check or replace your TV TUNER Unit.
by serviceing professionls.
Oct 20, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
No network
if your phone does not have signal you have to buy the new internal antena relace the old one with the new one or simple clean the gold doted were the antena is positioned with a methylyted spirit together with the antena that my cure the problem.advice by dogy
Sep 05, 2007 | Samsung SGH-D500 Cellular Phone
32 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
