Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Printing "D" sized PDF drawing on 11 x 17 paper is off center
Print is shifted towards the upper left corner, but looks centered in preview. Can't find any adjustment or settings in Printer setup.
  • deut65 Mar 19, 2009
    The problem was solved by selecting/checking "fit to printable area" in the printer settings. Thanks.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you printing in portrait or landscape?
  • Konica Minolta Master
  • 2,794 Answers
Thats the ticket. I have heard some customes having trouble getting it to print to scale using office applications. Part of it has to do with the gripper needed to get the paper to go through the machine. A firmware upgrade can take care of it as well if you fell it is too exagerated.
Posted on Mar 20, 2009
How do I center the label on my printer so it prints in the middle
there should be a setting in the printer setup that gives you options on how you want the printing set up, such as maximum, border, no borders, and centered. Use the preview to be sure of it before printing.
Nov 03, 2014 | Avery Dennison Ave-2181 Filing Mini-sheet...
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Print preview is not the same as what is printed
Click
  1. <Page Layout>
  2. <Margins>
  3. <Custom>
  4. Then click the "center Horizontally" box
Apr 15, 2014 | Microsoft Windows 7 Professional Upgrade...
Missalignement problem! Printing or copy-ing, my dialta di520 is not printing in center (off centered)... is starting to print at 7-8 mm from one long side and 6-7 from the short one. If i print / copy a...
First is this a problem with just one draw? Move to a different draw. lets eliminate the draws and or the by pass tray. Does this happen when using the Document feeder. Place the original on the big glass does it happen then? Secondly have you the correct size paper are you using metric size paper and the machine thinks it is inch size paper. Have to let the copier know what country it is in. Does this happen when you print or when you copy? Check the guides in all the paper draws they have to be snug up against the paper
Aug 23, 2013 | Minolta DiALTA Di520 Laser Printer
Printing from InDesign CS3
even if you have the same document size and paper size the printer will not print exactly to edge to edge... so please select scale to fit and check the percentage of scaling if it is more than 95 then your document should look as big as it is desired
Mar 13, 2009 | Epson Stylus Pro 4800 InkJet Printer
Canon MP600 not printing on full page - in upper left corner
I went to the Canon website and downloaded the drivers for the printer and it printed out right--on a full page.
Feb 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printing invitations
if you are printing from word 2010 and have an HP printer;
-set up your document on your screen how you want it to look, go into your print preview section, your printer should be listed towards the top of your page and directly under it should be "printer properties" click here, select the features tab in the next window and change your paper size to the correct size for your document.
-you may also need to go into the page layout tab in the main screen, select the size button, click on "more paper sizes" at the bottom of the window, select the paper tab and change the size of your paper again to the size of your document
-lastly, while in the "paper" tab window select "print options" towards the bottom right corner, left side of new screen click on advanced, scroll down to print and make sure there is NOT a check in the box that says "scale content for A4 or 8.5 x 11" paper sizes
Jan 22, 2009 | HP Officejet 6310 All-In-One InkJet...
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
May 30, 2007 | Printronix LaserLine L1524 Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
166 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
