Question about Exercise & Fitness
I have a Healthstream Blizzard HS1720T treadmill keeps blowing 10 amp fuse and E-1 comes up on the screen.
  • 246 Answers
SOURCE: I have a healthstream treadmill model LS3T and it
if you take the motor shroud off the front of the treadmill, you'll find wiring and connectors. check them and make sure none are loose, cracked, corroded, pinched, rubbing, or frayed and touching metal. also check under the display, there should be an access panel you can unscrew and remove to check the connections in there as well.
Posted on Feb 17, 2010
SOURCE: treadmill keeps blowing fuse
I can't solve your problem cause I am haveing the same, But i lost my fuse on the way to get a new one can you tell me what the fuse is? Volts? MA? All that?
Posted on Jun 17, 2010
  • 218 Answers
SOURCE: how can fix my healthstream LS720T treadmill?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 11, 2010
Testimonial: "awesome!!!! just briliant.........i just follow the procedure do a bit of adjustment then presto!!!problem solved !!!! thanks a lot !!!!!!!!!!!"
ercupa190
  • 12223 Answers
SOURCE: Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Posted on Jun 13, 2012
ercupa190
  • 12223 Answers
SOURCE: I have a T802 Healthstream treadmill that has an error 2 on it? Can't clear it.
follow this steps and fix it. God bless you
Instructions
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Posted on Oct 16, 2012
NO turn signal or neutral light, no speedometer or horn working. Changed 10 amp fuses but they keep blowing?
10 amp fuse is small a few things that you can do. go to a 15 and turn every thing on snd see if it blows and how long. if it don't blow in 5 mins. your good if it does blow then you have a wire problem. if so. unplug every thing that has to do with that fuse. and plug 1 in at a time UNTIL the fuse blows. good luck.
May 03, 2016 | 1999 Yamaha V Star 1100 Custom
10' canam outlander 650, keeps blowing injector fuse. Check engine, DPS, and low batt amp warning comes on first, any ideas? Doesn't restart with out jump and new fuse.
amp blowing fuses ' High Lifter Forums
forum.highlifter.com > ... > [Most Popular Discussions] > ATV Accessories
Dec 31, 2007 - 2006 Can-Am Outlander 650XT Bombardier ... RE: amp blowing fusesMonday, December 31, 2007 10:31 PM (permalink). I want to use an ...
Aug 30, 2015 | Cars & Trucks
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Healthstream gold series model no GS1160T is coming up with E1error code. What does this mean? Treadmill will run for a few seconds then switch off
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Adjust the Speed sensor according . Test for open or faulty458ecb9c-392b-4a17-8105-4b76ec52d9b4.gif192107ed-2567-439d-9172-83a32cb4381b.gif
May 31, 2013 | Exercise & Fitness
Instructions
Oct 15, 2012 | Exercise & Fitness
God bless you
Jun 13, 2012 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Mar 16, 2012 | Exercise & Fitness
I have a sportsart 6300 that keeps blowing up Q2 and Q3
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Jul 12, 2009 | Sportsart 6300 Treadmill
I turn it on, it only hums then dies.
That "switch" is really a 10 amp ciruit breaker, which is a resettable fuse. Like any fuse, if resetting/replacing it just causes it to blow again there is fault in the internal circuitry that is drawing too much current.
You problem is likely to be one of the following things:
1. The motor has failed with an internal short.
2. The motor or something in the belt drive has siezed.
2. The motor controller board has failed
3. A connection wire has shorted, possibly by the insulation being worn away rubbing against a metal part.
Mar 14, 2009 | Exercise & Fitness
Exercise & Fitness Logo
155 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
