Question about Kenmore Dryers
Kenmore model 110.7/6494
Need to know how to remove bottom panel to clean lint
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Posted on Oct 29, 2008
  • 8 Answers
SOURCE: Need to clean out lint trap
No, the lint basket/grid does not remove from front panel. This is what drives me nuts about this dryer......the worst lint catch design on any dryer I've used. I have purchased several vac attachments to get down in there, but every so often I take it apart.
You have to remove the bottom lower front panel of the dryer. It's not extremely difficult, just time consuming. I copied and pasted how to do so below thanks to a poster from another site, as I'm not so good at explaining these things in writing.
" Unplug the dryer. Remove the two screws that connect the front panel to the lint trap housing.
- Open the upper cabinet dryer and unscrew the four screws that span across the rear of the control panel.
- Move the control panel up and be aware that you will have to detach at least one electrical connector to get the panel out of the way (This will allow you to swing the control panel to the left).
- Remove the five srews located across the top of the bottom panel (Previously hidden by the control panel).
- Swing the top of the panel out and gently pull up to remove the bottom of the panel from the brackets.
- Unhook the yellow moisture sensor harness 2 wire electrical connector on the lower right side which will allow you to swing the panel to the left. "
You can download the Service manual online. It has the photo's to show you how. Not sure if this site has it but some other sites do. If you type in the model # + service manual in a search  it should bring up several sites to get it. You may have to pay for it. I ordered one soon after buying the dryer.....you never know when you may need it and being able to order the parts and fix it yourself saves a bundle, especially when it's one small little $5.00 part that could cost $100 or more on a service call. The electrical connections inside the front panel and on the digital console are not difficult to remove at all. I wrote on the inside panels w/ a marker as I removed them the first time I opened it as to how they hook back up. You can also take pics as you go w/ a digital camera if you have one. The 3 plug in connectors on the logic board are 3 different sizes, so they only can go back in one way.
I just got finished putting mine all back together last night.......I had a chewed sensor harness thanks to a chilly tree rat thinking my dryer vent on the roof looked like a toasty place to keep warm.....not realizing he'd fall 20ft straight down w/ nowhere to go but into dryer doing some damage trying to get out.
Anyway, sorry if I wasn't very clear on things, as I said I'm not to good explaining these things in writing, but the service manual is a must.
Good luck and take care, Teresa ; )
Posted on Dec 07, 2008
Sea Breeze
  • 4655 Answers
SOURCE: I have a Kenmore Elite model # 11063032101. It
If exhaust is blocked or restricted from back of dryer to outside of home it will cause the dryer to over heat the high limit switch. Repeated overheating will weaken the over load switch and it will need to be replaced if normal operation can not resume without restriction. Sea Breeze
Posted on Mar 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
How do you open up the kenmore dryer model 80311900 with the front control panel for cleaning out lint
To disassemble the machine, disconnect the power!
I believe that model has two screws in the rear edge of the top panel. Remove the screws and slide the top panel to the rear and remove it. Then remove two screws, from inside the machine, that hold the front panel in place from the back. Label the wires, then disconnect them. Tilt the front panel forward, then lift the bottom of the front panel up.
Mar 05, 2017 | Kenmore Dryers
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
My dryer will not dry effectively, it is very slow to dry even on the high heat settings, any ideas?
i looked up your model number and you have a gas dryer not electric,if the vent line is clear and the metal duct that the lint filter slides into is clean i would say you have bad gas coils located on top of the gas valve,when the coils go bad they will work correctly for the first 15 to 30 minutes,when they heat up they fail and the flame won't ignite,so do this remove the screws that hold the bottom panel on,remove the panel and vac out any lint you see,if you have a shop vac you can set the vac up to blow and blow off the motor and blow all the lint forwards and vac it up,do this with the dryer unplugged,remove the lint filter and take out the screws that hold the metal duct in place and clean the duct out,put it back together except for the screws that hold the bottom panel in place but just stick the panel in place,put some clothes in and start the dryer,after around 20 or 30 minutes remove the bottom panel so you can see the ignitor,if the ignitor glows orange but the flame doesn't ignite and the ignitor goes out then you have bad gas coils.you should take the bottom panel off and remove the lint filter duct and blow and vac it out once a year,also if you vent line is long remove it from the back of the dryer and blow it out with a leaf blower,make sure nothing is blocking the outside vent like a cage or a piece of screen so the lint can blow out and not get blocked.the part number for the coils is 279834 and they are around 25 dollars,unplug the dryer,remove the bottom panel,remove the two phillips head screws,remove the cover,slide the coil up and off of the post,unplug the wire and connect it to the new coil,watch out on the big coil,there's a spacer that has to stay on the post,sometimes it gets stuck in the old coil when you remove it,let me know how you make out.
Mar 19, 2013 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dryer no heat . 90 series model 110.70902990 have power, did vacum lint from access panel@ FRONT
unplug the dryer,remove the lint filter,take off the bottom panel and remove the duct that the lint filter slides into,clean the duct out,while you have the duct off on top and to the right of the blower wheel housing you'll see a 3390719 thermal fuse,remove one of the wires and check it with your meter to see if it's good,most of the time if the dryer hasn't been cleaned out the fuse will blow,the dryer runs to hot and the fuse is a safety so you don't have a fire and so the dryer doesn't run hotter than it should. vac out the inside of dryer and if you have a shop vac it blows on the other side,blow off the motor and blow the lint from the back forwards so you don't have to remove the drum,next you have to clean out the vent line,if it's a long run from the back of dryer to the outside flapper i use a leaf blower to blow out the line,you should clean the dryer once a year,if the fuse is good you need to check with your meter the ignitor,the sensor and the gas coils to see what's bad,if you need anymore help let me know,good luck,when you're reading anything out with the meter make sure you remove at least one of the wires or you'll get a false reading
Mar 16, 2010 | Kenmore Dryers
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
Feb 15, 2010 | Kenmore 73952 Gas Dryer
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
How to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
Jul 03, 2008 | Dryers
Kenmore dryer (electric )
Almost always a thermal fuse.
If your lint screen is in the door, follow these directions:
Disconnect the power. Remove the lint screen. Slide a putty knife in between the toe panel and the bottom of the door three inches from either side. this will release the clips at the top. Tilt the toe panel out at the top and lift it off the clips on the bottom.
Remove the two 1/4 in screws at the top of the metal triangular box around the lint screen. There may be one more ***** near the bottom right of the box holding a gold bracket in place. Remove that ***** or lift the box off the black metal clip at the bottom.
You can now reach the thermal fuse. It's the white plastic part with two wires on it near the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
If your lint screen is in the top of the machine, follow these directions:
Disconnect power. Remove the lint screen. Remove the two Phillips screws under the lint screen handle.
Pull the dryer away from the wall about 2 feet or more. Disconnect the vent pipe from the bottom of the dryer. Remove the nine 1/4 in screws holding the back panel on, along with the small metal cover. Lift and remove the back panel.
You can now reach the thermal fuse. It's the white plastic part with two wires, close to the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
While you're back there, be sure to clean out the long metal box that the lint screen goes into (four more 1/4 inch screws.)
Mar 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
298 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
