Question about Garden
How to change choke shaft on briggs 135292 0071 01
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Will start with choke up and will run for about one minute
Sounds like the filter may be plugged up..not expensive change it see if that helps..good luck..
Dec 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Smoking and loosing power
Blue smoke means engine worn or too much oil in sump.
Black smoke is caused by too much fuel being sucked into carburettor.
This can be caused by a dirty air filter, choke being left on after engine is started or fault in choke system if automatic choke fitted.
Feb 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
How does choke work on 20 horse briggs the throttle only has turtlespeed and rabbit no place marked choke
Many have auto chokes, which are set to close and open essentially with spring pressure. You can verify this by looking into the intake, ahead of the throttle plates. Other designs use a priming bulb to accomplish the same function.
Nov 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor will run fine with the choke on , but push
The governor is out of adjustment. It will be located on the side of the engine with a rod pointing downward with a weight
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawm mower engine will only run on choke
the carb is gummed up with laquer. take it of the motor and soak it in some solvent for an hour. but first take off the float cover before emersion.
Nov 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
