Question about Saeco Odea Giro Plus Coffee Maker
Correct way to froth your milk witha saeco odea giro plus
SOURCE: saeco milk island - no froth
Molly -- re: position of grey plug. I don't think this makes any difference at all. The key issue is to make sure those two slots are clear of debris or moisture. One month on and I have continued to achieve thick frothy milk purely from rinsing the milk island parts under a running tap, leaving them to dry, and then giving a short sharp blow to the two slots in the valve before reassembling.
Good luck
Guest with Solution 2
Posted on Apr 20, 2008
EsWorld
  • 1618 Answers
SOURCE: frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Posted on Feb 27, 2009
SOURCE: Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Posted on Apr 12, 2009
SOURCE: Saeco Odea Giro - disassembly
Hope this can help:
I managed to take mine apart because I was having a lot of leaking steam from the steam wand (as posted earlier). I followed your instructions, and all worked very well. Just to prepare readers, this is what I found. The green seal on the steam end was torn, as previously described. I noticed it start to "drag" a bit during use (daily for the past year), and it must have stuck and torn over time. See photos. I replaced with a part from ACE, see photo. Be sure to lube before re-assembly. Hope the photos help!
BA
Posted on Aug 26, 2009
  • 81 Answers
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Posted on Jan 21, 2010
Steam wand boils water but does not make any froth
Making froth with a steam wand is an entire technique. Also depends if it has a panarello or not
Jan 06, 2015 | Saeco Odea Giro Plus Coffee Maker
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
Frothing valve leaks water when not in use
Feb 23, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro tuning on/off
turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
Dec 09, 2008 | Saeco Odea Giro Plus Coffee Maker
Temperature of the coffee?
Not what i know on Talea and Odea, but on Primea can you do it.
Jul 30, 2008 | Saeco Talea Giro Espresso Machine
Saeco Odea Giro Plus Coffee Maker Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
