Question about Ugly stick Shakespeare Synergy Steel Spincast Rod / Reel 6 Combo
How do i take a synergy steel reel apart - Ugly stick Shakespeare Synergy Steel Spincast Rod / Reel 6 Combo
The plug prong broke on my Electrolux Epic 6500 SR vacuum. I cut it off and was going to replace it with a new plug. However, I mistakenly rewound the cord and it went all the way into the body.
You will likely have to install a new cord reel. Cord reels have a long tightly wound steel spring which can fly out causing injury if you attempt to take it apart.
Mar 04, 2017 | Vacuums
Why is my reel able to reel both directions instead of locking in place?
Sounds like the slider switch didn't get back into it's socket properly, take it back apart and look at that.
Jan 31, 2015 | Abu Garcia 7000i RED Baticasting Reel
User manual
can not get control panel to work on hydro massage spa
model ALCOY Aqua4fun
style gold
Sep 21, 2013 | Shakespeare Surf Fishing Rod and Reel...
Reel wont engage to wind in line
Depending on the reel it could come apart differently. On a closed face reel you normally turn the top half about 1/4in. and then the top pulls off. On a open faced reel if you look atop the cylinder that the line wraps around there should be a screw on there. Or sometimes the whole top of the cylinder unscrews.
Dec 08, 2012 | Boating
Think it may be a line tension problem. every
Wow, I can't believe that. That reel is very simple and shouldn't do that. I would guess that it's a problem with the line. Usually a real like that comes with line. Sometimes line is bad and it's very twisted due to being the last on the spool before it's put on your reel. I would suggest you buy some quality line, like Trilene or Stren and use about 6 lb test. I like the limp kind (read the box and it will tell you what type you are buying). Limp line means fewer twisting/tangling problems. Good luck. Alley
Jul 26, 2009 | Sport & Outdoor - Others
Power cord broken inside reel
the reel doesn't come apart, its a replaceable item. the only place that you can get another one is through sears.
Jul 19, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Mar 24, 2009 | Shakespeare Surf Fishing Rod and Reel...
Knukles hit handles on synergy kayak
This may mean that you are not holding the paddle correctly. To make sure that you have a proper grip hold paddle in both hands and bring over your head. Make sure that your hands are approximately shoulder width apart bend arms so that they create a 90degree angle on either side of your head, this will ensure that your hands are in the proper position and you can then lower the paddle and begin paddling. This should eliminate any contact your knuckles have with the boat.
Mar 22, 2009 | Synergy Mad River 14 Kayak Canoe with...
Ugly stick Shakespeare Synergy Steel Spincast Rod / Reel 6 Combo Logo
37 people viewed this question
Top Ugly stick Fishing Experts
ray gallant
Steve P
Steve P
Andrew Taylor
Andrew Taylor
Are you an Ugly stick Fishing Expert? Answer questions, earn points and help others
