Question about Frigidaire Washing Machines
Can i bypass the reed switch on my frigidaire 053 washing machine?
3 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: FRIGIDAIRE WASHER is the sensor switch the same as a reed switch
yes !!
Posted on Apr 18, 2008
TheMobilian
  • 8220 Answers
SOURCE: instructions for a fisher paykel 053 washing wachine
Directions
Posted on Apr 24, 2010
Is it at all posable to bypass the lock on a frigidaire affinity
You never want to bypass any safety device. If this is a front load machine and the door did not lock properly, water would get on the floor if the safety device was disabled.
Jul 27, 2015 | Frigidaire Washing Machines
Bypass LG WF-T9250PP lid switch
Before bypassing the lid switch, check whether the magnet on the lid is OK. The reed switch is under the cover adjacent to the position of the magnet when the lid is closed.
Jun 09, 2015 | LG Washing Machines
Can you by pass the lid switch
I appreciate your inquiry, friend!
Based off what you have described you would like to bypass the lid switch on your Frigidaire washer. It is not recommended to bypass this part. Doing so could lead to a fault within your washer. I hope this information is helpful. -Matt
Feb 13, 2015 | Frigidaire ATF7000ES Stackable Front Load...
Where does the reed switch go on my front loader
Hello friend, thank you for your post!
I see that your question is labeled under Frigidaire washer, GLTF2940ES. I have located the parts manual for your appliance and it will provide you the location of your reed switch. I hope this helps. -Matt
Frigidaire Manual Search Results
Sep 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
E14 message on whirlpool washing machine/dryer
To prevent the washer from operating while the detergent drawer is open your machine has what is called a "reed switch". The reed switch is controlled by this magnet, so that when the drawer is closed the magnet causes the reed switch to close and this tells the control board to go ahead and run the machine.
Your error message is telling you the reed switch it not working, so they want you to check the magnet to make sure it is still in place and is working.
Dec 05, 2012 | Whirlpool Washing Machines
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
DDO indicates on the display. Found a magnet that came off of the door dispenser, where does it go on the dispenser?
This is a door sensing magnet . When its in its place it tells the machine that the detergent dispensor is closed and will alow the machine to fill detergent dispensor it goes in the upper right corner of the detergent dispensor handle ... where location 49 is on attatchment newer models have done away with the magnet and the reed switch that senses the magnet this can be jumped out permanetly on the backside of the control panel where the detergent dispensor comes in is a white supository called a reed switch cut this and splice the two wires together and you never have to worry about losing the magnet again... or purchase new control without reed switch......you can always call for tech assistance dr.appliance dr_appliance.png
Feb 23, 2011 | Frigidaire GLTF2940ES Front Load Washer
Samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then 1. Turn AC power OFF, unplug from wall 2. HAVE YOU TURNED THE POWER OFF? 3. Unscrew two visible screws on the back of the machine near the top 4. Take back lid off by pull up which will expose all the wires at the back 5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw) 6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it. 7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test. 8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
Nov 06, 2007 | Washing Machines
Washing machine has packed a sad
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Oct 06, 2007 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
76 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
