Question about Craftsman Garden
How to disconnect the kill switches on a craftsman lawn tractor
2 Suggested Answers
  • 6468 Answers
SOURCE: craftsman lawn tractor turns over but won't start
i would check the switch on the brake/clutch it has 2 switches built into one jump it with a paper clip to test it
Posted on Aug 01, 2012
Where are the kill switches located on my Craftsman 917.256711?
most lawnmowers have one for the reverse and under the seat some have them on the brake pedal to start it if it breaks it wont start
Aug 15, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where are kill switches on my Craftsman 46" Hydrostatic lawn tractor?
how old is the mower? Usually one in the seat & under the engine cover where you depress the clutch/brake pedal. Good place to start. Hope it helps.
Aug 14, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How can I check kill switches/relays on a craftsman 17.5 Kohler riding mower
get and ohm meter and see if you got voltage coming in on the b pin and when you turn the key on see if you hae the voltage coming from the pin that is marked with a s,
if you disconnect the switch you'll see on the pin's letter's
there should be a B,L,S,G,etc.
Oct 06, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is kill switch
there is not a kill switch. It should be keyed.
Oct 05, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman lawn tractor turns over but won't start
Jul 31, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Test seat switch
Disconnect it from the seat. Keep the plunger down with your fingers as if you're sitting on it with the seat, and start the machine. Let the plunger go and it the machine is running while in gear, the switch is bad. Also, you can use a multimeter to check continuity with the plunger up and down. That will tell you if it's working or not.
Jul 31, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
I just recieved craftsman lt1000, 19.5 b&s, 42 in. cut with hydrostat that was fine but I think I tripped a kill switch and it won't even try to engage the starter. What kill switches are there beside...
You didn't indicate what model number you have. You can download a manual here:http://www.managemylife.com/mmh/owner_manuals/21205/CRAFTSMAN-Lawn,-Tractor-L0306104?brand_name_search=917272672+CRAFTSMAN if the 917272672 isn't the right model go to www.searspartsdirect.com and enter you model number. When the parts come up look over on right had side of page for button to select manual. To start, you must have foot on clutch, PTO disengaged. The seat switch doesn't come into play until the PTO is engaged. Check for voltage at the B terminal on the start switch to be sure fuse is good. From there check the S terminal when you turn key to start. From there it goes to the clutch/brake switch (when depressed) then to pto clutch then to solenoid. GOOD LUCK!
Aug 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Craftsman riding lawn mower 42 will not stay on after taking foot of brake pedal
the "safety deadman switch" is the problem, however, we call it simply "the seat switch" - flip the seat forward and you will see wires going to the middle of the seat, the connector is probably slightly unplugged - wiggle it back on to make a good connection - this is a verry common problem [the unplugged switch is telling the tractor that there is nobody on the seat and it kills the engine]
Aug 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
117 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
