Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
Popping noise We have a Maytag MBF2556HEW for the last 2 years. It has been making a popping noise for some time now and it seems to be getting more frequent and louder. And then today, when the freezer drawer was open there was a hissing noise coming out of the freezer but the ice maker was turned off. I was trying to figure out if this is a start of a problem or normal. Thanks for your help
  • 3 more comments
  • Anonymous Nov 13, 2007
    I have a kenmore bottom freezer and have the same problem
  • Aghauge Dec 31, 2007
    when we open the bottom freezer from time to time it makes a hissing and poppin noise-it definately sounds like water or some fluid hitting a hot service somewher. We pinpointed it to the vents in the back whihc are warm to the touch. IT is the dead of winter here in Minnesota-so not sure I beleive the heat and humidity arguement. Condensation is hittong something hot. My biggest concern is obviosuly safety.....afraid of electrical fire, etc. Any other thoughts??
  • Anonymous Jul 24, 2008
    I have the same problem Mdel# MBL2556KES
  • heli_pilot Jul 24, 2008
    I have the same problem Model # MBL2556KES
  • Anonymous Mar 19, 2014
    Samsung 31 cubic feet. Bought Feb. 2014
    Novelist:
  • 159 Answers
What you are describing sounds like the refrigerant flowing through the evaporator that is in the freezer. when the weather is hotter and more humid out the unit has to work harder to keep it cool so you may hear more noise due to the compressor running longer and more often. so most times it is normal to hear it at some point in time.
Posted on Aug 04, 2007
SOURCE:
Popping/clicking noise
for window type ac, it must be positioned on level, to avoid flexing it's case.
Jun 04, 2013 | Haier Heating & Cooling
MTB2456DEW makes a popping noise every hour or so
thats nothing to worry about,its just the defrost cycle and its drippingwater on the defrost heater and sizzling as it evaporates,this sound is normal
Jan 07, 2010 | Maytag Refrigerators
My Maytag refrigerator makes a loud popping noise. It woke me up at 1 am. Refridgerator is 10 years old no ice maker. The sound is pretty loud. Is this a bad sign? Is there any danger here? Should I be...
the popping noise you're talking about, could it just be your self-defroster in operation,sometimes if there a lot of ice and it operates a long time, there could be expansion noises,such as the refrigerator walls expanding/contracting from the heat of the defroster,if it's water you will hear a sizzling popping sound,nothing to fear dear
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
My Maytag Wide by Side refrigerator has been making loud popping noises and now the freezer is not cooling properly. What is causing this?
Does not sound good. We need to find ou where the popping noise came from first. Not cooling is because it sounds like the popping noise is from that area but for sure that area. It could be a failed control board and shorted out the compressor relay.would like to go and do this yourself of have a technician like myself lead you through this? I'm going to get the service manual and if you would like a copy I will get it for you, Thanks and let me know soon, Sea Breeze
spotted cow make sure the model number above you post is correct before we begin
Nov 10, 2009 | Maytag MZD2766GES Side by Side...
Freezer noise and defrosting
You need to contact a repair shop ASAP.
May 01, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag LDG9334AAE Gas dryer making popping noise from vent
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
May 07, 2009 | Maytag Dryers
Sony DAV-SB300 Audio Popping
Could be component breakdown. If you can isolate and replace the bad ones you should be back to normal.
May 08, 2017 | Sony DAV-SB300 System
AT 4060 valve microphone
Check out this gearslutz thread. It's pretty informative & the person found the solution to be to install a new tube/use a dehumidifier.
Dec 04, 2007 | Audio Technica Audio-Technica AT4060...
Popping noise
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Feb 27, 2007 | Sanyo AVM-3680G 36" TV
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
326 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
