Question about Mitsubishi Heating & Cooling
Daiya not working run and timer check light flashing
I need to download Mitsubishi RKN502A User guide
Search Results
    [PDF]user's manual mitsubishi daiya room air ... - 3D Air Sales Ltd
    www.3dair.co.uk/DOWNLOADS...manuals/O&M%20RAC%20-%20SR...
    Thank you for purchasing a Mitsubishi Daiya Air Conditioner. To get the best long-lasting performance, read and follow this User's Manual carefully before using your ..... Symbols which appear frequently in the text have the following meaning:.
    I need download the user guide of Mitsubishi rkn502a rem
Dec 26, 2015 | Cell Phones
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
My EJ351 programmable timer has work perfectly since 2004. A few days ago the red light just started to continuously flash. I turn it off to rest and regrogram but no luck, the indicator light still...
What is amazing is that you know the year of purchase, AND remember how to set the timer.
1) Try turning off circuit breaker and see if timer resets.
2) Buy cheap circuit analyzer and plug into outlet on same breaker and see if line is clean.
3) EJ351 has limited 1 year warranty.
I test timers: usually when in-wall timer goes bad, it needs to be replaced.
There are no repair parts.
Google search: Intermatic EJ351 timer
Amazon sells EJ351
http://www.amazon.com/dp/B000Q9YUGU/ref=asc_df_B000Q9YUGU1408425?smid=ATVPDKIKX0DER&tag=nextagus0039178-20&linkCode=asn&creative=395093&creativeASIN=B000Q9YUGU
Aplus supply sells Ej351 timer.
http://www.aplussupply.com/intermatic/timer.htm
I buy timers from both these suppliers.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 28, 2011 | Intermatic Programmable 24 Wall Switch...
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
I have a mitsubishi daiya model SRC56HAA have lost the manual don't know how to get the cooling working
Is it possible to control the Mitsubishi Daiya Split Type Indoor Unit Model Number FDUM321HKXE2 as follows. We have an energy management system that controls the power supply to the room. This is done by using a door contact via a mini PLC to close and open the system The room is powerd up, all electrics and A/C as soon as the door is opened and closed after a 10 min. delay when the person leaves the room. I am trying the regulate the A/C not to power up on entrance. I need it to operate after close down only by requiring a manual operation of the wall control unit, i.e. it must be switched on manualy at each entry. Any advice ??? Regards Bill
Nov 19, 2010 | Mitsubishi MS17TN Air Conditioner
Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Apr 18, 2009 | Fujitsu 24R1 Air Conditioner
Timer quits shutting the lights off and time flashes 12:00AM
Intermatic is a reliable mfg. if you have a it wired to directly to a light and only a light, you most likely have a defective timer. Bring it back and purchase a rotary timer with on-off switch. more reliable. I too installed the same type of timer and went through 3 before installing intermatics rotary timer/switch.
Jan 24, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
