Question about Acer Aspire 5100 Notebook
Wont reboot turns on goes to acer window press f2 and thats it
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    kindly check hard disk try to restore OS thru following procedure pls if it doesnt help then change hard disk ur hard disk has crashed
    When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
  • 167 Answers
Hi, press and hold the power button for 60 seconds, then turn it on. this should reset the unit. if still no boot try a disk utility, like acronis max blast,ect. hope this helps you out. good luck!
Posted on Mar 14, 2009
My acer aspire 1 725 wont load due to errorcode 0x00000f and cant get into bios to change boot options how do i fix this problem
Shut down your computer completely. Once it has been turned off, press the power button to the "On" position to restart the system. Within the first 10 seconds, press down and hold the F2 button for about three seconds and then release it. Within five to 10 seconds after pressing and holding this button, you should see the BIOS setup screen on the monitor.
Dec 30, 2013 | Acer Computers & Internet
How can i getthe bios for may acer aspire one series model zg5
Things You'll Need:
  • Acer Aspire laptop
  1. 1
    Click the "Start" button found at the bottom left hand side of your desktop. Select "Turn Off Computer" in the "Start" menu options.
  2. 2
    Click "Restart" in the "Turn Off Computer" dialog box to reboot your computer.
  3. 3
    Watch your computer's reboot display closely. Press "F2" when you see the system keys display at the bottom of the screen, just before the Windows splash screen appears, to access the BIOS panel.
  4. 4
    Make any needed changes in the BIOS and hit the "F10" key to save your changes and exit the BIOS. Your computer will complete the startup process and launch Windows.
Read more: How to Access an Acer Aspire BIOS ' eHow.com http://www.ehow.com/how_5809235_access-acer-aspire-bios.html#ixzz1E2WkwLWf
Feb 15, 2011 | Acer Aspire One PC Notebook
My Acer Aspire 5520 wont power up when i tried to turn on. Battery getting power supply. orange light is glowing. but i pressed power button, it does not turn on. pls give me a solution. I removed my...
start your computer keep pushin f2 now youll see first use arrow keys go to were it says change reboot to f12 then restart your computer then it be set on a f12 press f12 then it will ask to run your windows go to that one.
Jan 27, 2011 | Acer Aspire 5520-5908 Notebook
When turning on my acer aspire desktop a black screen comes up with the following and wont start up: Verifying DMI Pool Data...... Update Success Boot From CD: DISK BOOT FAILURE INSERT SYSTEM DISK AND...
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Aug 21, 2010 | Acer Aspire™ T180 PC Desktop
I have a acer one i have tried to turn it on and it goes to the safe screen and wont open the programs there is no cd rom so how do i get it to work wendy
try pressing f12 or f2 or whatever it is on your computer when it is turning on and see if you can select start windows normally from there. hope i helped :)
Aug 07, 2010 | Acer Aspire One PC Notebook
No good computer stuck no good i say
While the pc is powered on, load the windows cd into the cd rom and restart the pc by pressing the CTRL+ALT+DEL keys, when the pc reboots you should see a black screen with white letters asking you to press any key to boot from the cd.
Carefully following the options install Windows and then to repair the operating system. NOT the repair console option.
If you are not asked to do a repair then stop as this solution wont work and you will likely need to reinstall Windows.
At this point windows should repair any damage files and reboot. Following the reboot, do not press any key, instead wait for Windows to boot normally, you can remove the cd after Windows boots.
Jun 01, 2010 | Acer Computers & Internet
Start up issues
go onto the bios after pressing f2 and look through the options and tabs and tick or change whichever option is about the setup or start up
May 01, 2009 | Acer Aspire 5315 Notebook
Computer seized and wont let us do anything
hi!
you need to strip your laptop to get to the cmos battery leave it out for 4 hours then assemble the laptop ,it should work:)
regards craig
Feb 15, 2009 | Acer Windows Vista TL-562G Notebook
Laptop wont boot
Press F2 and try to Load the default values and reboot.
May 20, 2008 | Acer Aspire 5100 Notebook
My Acer Aspire 3000 has a blank screen
When you get in setup check the time and date and see if correct, if not; correct it and save settings and exit, then it should reboot. If the time is correct and date then you will have to reboot the system and keep pressing F8 while its booting, this will take you into safe mode, you need then to choose last known good cofiguration and hit enter, hopefully you should now get into windows.
Sep 05, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
