Question about Kichler Hardware & Accessories
How do I set the dial timer for a Kichler Grasslin 15T900AZT landscaping light transformer? Previous owners didn't leave manual.
We're not sure how to set the dial timer/pins. It looked like it was set from 6 to 10 p.m. , but the lights never came on until after 1 a.m. and went off around five.
jeltey
  • 44 Answers
SOURCE: Malibu landscape transformer
If it is keeping time try moving the stops. If it is not keeping time the motor is probably burned out. These transformers don't have a lot of serviceable parts to them.
Posted on Dec 04, 2008
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Posted on Apr 15, 2009
protek480
  • 1723 Answers
SOURCE: How do you set the timer on Malibu 300 watt
Make sure there is power to the plug. Then set the clock and install the on and off pins to control the lights. The on/off switch is for manually turning on the lights. The clock should run as soon as it's plugged in.
Posted on Jul 02, 2009
  • 3 Answers
SOURCE: One of my five EJ500C timers controls 6 outdoor
The EJ500C is designed only for standard incandescent lights, not chandelier bulbs, CFLs, etc. Replace it with the ST01C, and you'll be fine. Intermatic may even exchange it for you if you if you complain to them.
Posted on May 02, 2010
SOURCE: I need the timer pins--the
Open following link for Intermatic/Malibu ML series trippers plus power pack tip
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jun 11, 2011
How do i set the Kichler 15E120BK landscape timer?
http://waterheatertimer.org/Kichler-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Depends on which timer.
Some Kichler have analog timer built in.
Most Kichler timers are made to run constantly... with option to plug your own timer into the outlet located on front of Kichler, or to plug in a kichler-model photoeye.
Gene
Aug 26, 2014 | Hardware & Accessories
Our Intermatic clock operated switch Model T25/16FMD works and then stops. It is hanging up on something. You can spin it but it does not turn on and off the landscape lights. Any thoughts?
Replace timer.
Copy following link to identify timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#KM
If analog timer starts hanging, then motor is probably getting weak.
Use air pressure and blow out timer while rotating timer dial.
Turn power off and spay bit of highly flammable vapor from WD40 can while rotating timer dial.
Timers generally have 1 year limited warranty.
Replace timer.
http://waterheatertimer.org/How-to-wire-timers.html
Nov 17, 2012 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
The clock dial on my grasslin analog timer does not correspond to the time on the "2:00" arrow. how do i realign the clock dial to be in line with the arrow?
I don't know what the 2:00 o'clock arrow is.
KM series Arrowhead is located to right side of timer dial.
To set clock, manually rotate timer dial clockwise until current time lines up with arrowhead
If this is not your timer, then add a comment with description of timer for possible help
Jul 23, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
How to wire
Following manual has different wiring diagrams:
http://waterheatertimer.org/pdf/Kitchler-transformer-wiring.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
Kitcher wiring with boost transformer: 120Volt
Black hot from breaker connects to Black Line wire
White neutral from breaker box connects to wht (COM) wire
Output to light is shown.
http://waterheatertimer.org/images/Kitchler-wiring-1-1000.jpg
Kitchler wiring with block terminals. 120Volt
Bare ground wire connects to GRD terminal
Black hot from breaker connects to 120VAC PRI terminal
White neutral from breaker box connects to COM PRI terminal
Output to lights is shown.
http://waterheatertimer.org/images/Kitchler-wiring-2a-1000.jpg
Additional resource:
Jun 28, 2011 | KICHLER TRANSFORMERS - PROFESSIONAL SERIES...
I have a kichler 15pl300 where it does not transform from 120 Volts coming and it does not want to send out 12 V on the other side. The 120 volts has confirmed for be live.
I have been unable to locate manual for Kitchler low voltage products.
The troubleshoot page says check on-off switch, and put black tape over photoeye for two minutes, but does not elaborate on what to do.
1) Kitchler e-mail and contact information:
TechSupport@Kichler.com
Mailing Address
Kichler® Lighting
7711 East Pleasant Valley Road
P.O. Box 318010
Cleveland, Ohio 44131-8010
U.S.A.
2) Kitchler troubleshooting page has nothing:
http://www.landscapelighting.com//portal/faqs_page/portlet_landscape_faqs/cms/begin?portlet_landscape_faqsresource=/OpenCMS/sites/landscape.com/faqs/Faqs_Main_Page
Add a comment and say what you discover for others with Kitchler problems.
Open following link for Intermatic/Malibu troubleshoot:
Jun 07, 2011 | Kichler TRANSFORMERS - PROFESSIONAL SERIES...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Hardware & Accessories Logo
70 people viewed this question
Top Kichler Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
