Question about Fujitsu fi-5120C
Blue Tint on Document when Scanning in Color
Good morning!
When we scan a document that has a lot of black & white text and a color logo or stamp (like Draft for example), on the preview (before and after we hit Store) of the document it has a blue tint on the edges of the document making look like we made a bad color copy from a copier. Is there a setting or something we can do to fix this and make it look like an original document?
Thank you so much for helping me out!
Mike Smith
RTD
  • 4 Answers
SOURCE: Overall Blue Tint
You might try resetting the "settings" to factory defaults and then scanning again. I have seen strange tints if the settings get set incorrectly, not sure exactly what is wrong. However, using factory defaults corrects the problem, then change settings one at a time.
Posted on Feb 04, 2008
ServiTiendas
  • 44 Answers
SOURCE: Scan Snap - color/balck & white
You don't need to scan the doc again. If you have a graphics editing program (like Photoshop) you can change the mode to Grayscale and resave it. I bet you by now you probably have rescanned it anyway :)
Posted on Aug 22, 2008
SOURCE: noise when scanning document
Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
PA03360-Y110
Pick shaft
PA03360-Y112
Pick Bearing ‘M’
PA03360-Y107
Clutch
PA03360-Y106
Clutch Spring
PA03360-Y105
Pick Gear
Regards,
Eric F.
Posted on Feb 06, 2009
  • 615 Answers
SOURCE: After scanning the first document and saving the
your memeory does not allow to scan more than one documents and when you close and reopen it refresh the temp. memory in your system...try to clean all cach and and clean the system or close some of the background applications that is running.
Posted on Nov 07, 2009
  • 6 Answers
SOURCE: We just started to having a problem scanning
There is a horizontal offset and a vertical magnification adjustment in the scanning software settings.
Posted on Jan 27, 2011
My laser mfp 1815dn is reducing the size of the image of the document i am scanning. how do i get it back to scan and save a full page?
Welcome to Fixya!
Adjust the Scan setting to the defalult/appropriate resolution. See guidelines below.
Documents:
300 dpi black-and-white or 200 dpi grayscale or color
Documents of poor quality or that contain small text:
400 dpi black-and-white or 300 dpi grayscale
Photographs and pictures:
100-200 dpi color or 200 dpi grayscale
Thank you for using Fixya. Have a great day.
Jas247
Jul 12, 2011 | Dell Printers:Dell MFP Laser Printer...
I scanned a 17 page document to pdf and got a 15mg file which I could not sent by e-mail. Checking some other pdf files, I see a 47 page document that is only 5kb. What's the deal? BwO
Resolution you scanned it at as well as scanning in color versus black and white. Also, that 47 page document might be vector graphics and text rather than bitmap information.
Scan in 200dpi black and white to get a usable (readable) and small file. Should be about 100-200kbytes per page.
More info on scanning: http://en.wikipedia.org/wiki/Image_scanner
-=/ Daft Tech /=-
Oct 23, 2009 | HP Officejet 6500 Wireless All-in-One...
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Document Recognition
Hi!
Here is an OCR software which you can download for free.
Please click on the link to access free OCR (scan to text) software.
Thanks.
Jan 06, 2009 | Epson 2580 Perfection Photo Scanner
We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
The Scan Settings dialog box allows you to specify advanced settings for scanning.
Document Type
Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
Document Size
Select the size of document to be scanned.
Auto Detect: Detects document size automatically.
Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
Reference See the section below for details.
Scanning images Larger than the Platen (Stitch Assist)
When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
If not, some images may not be scanned at the correct positions and sizes.
You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
Select the resolution at which to scan documents. The following scanning resolution can be specified:
Text(OCR): 300dpi, 400dpi
Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
this should answer your question , feel free to post here agian if you need more help.
Regards, and thank you for using fixya.
Oct 23, 2008 | Computers & Internet
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
Apr 04, 2008 | HP Scanjet 5590 Flatbed Scanner
Fujitsu fi-5120C Logo
435 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
