Question about Freezers
Replace door gasket westinghouse freestyle fj383 upright freezer
Door seal broken
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
  • 1462 Answers
SOURCE: new freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Posted on Nov 29, 2008
mumma_1
  • 903 Answers
SOURCE: how to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Posted on Dec 08, 2008
  • 1144 Answers
SOURCE: Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Posted on Apr 08, 2009
SOURCE: Freezer does do not have a tight seal at the bottom
it's an easy question! ans: support your leg in the bottom part of the door and pull the top part of the door with your hand with a great force.......it will seems to be bendind. dont worry. it will just make the door parallel................have a nice day :-)
Posted on May 15, 2009
Why is my Hoover A Class upright freezer alarm light constantly on
1) It could be a short. 2) The thermo sensor that turns the light on could be defective and needs to be replaced.
Mar 24, 2015 | Hoover 9.9 cu. ft. / 280 liter Upright...
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
WHAT IS THE PROCESS IN REPLACING THE GASKET ON MY KENMORE UPRIGHT FREEZER
If it is a push fit gasket it simply pulls out and the new one pushes in to the groove. Warm in hot water before fitting to ease it in. If the seal is part of the door, you have to replace the door as a complete assembly. Rare models have doors that can be taken apart and reassembled with a new gasket fitted but i don't think Kenmore is one of those.
Apr 19, 2012 | Kenmore Freezers
Can i replace the door seal by myself on upright Amana freezer?
Hello.
Yes the door gasket is replacable. If the model number for your freezer is the one listed in your question (AFU2076AW) the part number for the door gasket is 4357120 it could be purchased at your local appliance parts tore or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Amana 19.6 cu. ft. / 555 liter Upright...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigedaire Upright freezer, Model says
to verify what i think could be the problem i would need the complete model number so i can recheck what i am about to tell you
the freezer has a heater where the door gasket seals itself on (not on the door behind gasket but on the freezer itself) see if you can feel if it is warm where the gasket rest on the freezer this help it get that solid air tight seal. and prevent ice build up on gasket
well this maybe one possible without being there its alittle hard to tell what else hope this was alittle helpful
Mar 13, 2010 | Freezers
Our upright freezer door will not seal tight with a vacuum anymore. The freezer fills up with snow from the air drawn in. I have defrosted it and cleaned the seal. What should I do now?
That could be one of two things, one the door is not aligned properly and more important the gasket has failed and needs replacement. The snow as you call it is ice condensed from the atmospheric air that is getting by the gasket. You may want to check the door gasket and sealing surfaces especially in the area of the "snow".
Good luck,
Gilshultz
Dec 01, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore freezer
if the gasket isn't torn and the gap isn't caused by a door hinge problem you might try putting some vaseline on the door seal. If that doesn't help you may have to replace the seal.
Dec 30, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
27 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
