Question about Sport & Outdoor - Others
How to erect a hillary hex doem tent - Sport & Outdoor - Others
ward_knutson
  • 64 Answers
SOURCE: need an instruction booklet for Wild Country Blaxland 64283 Tent
If you go to www.coleman.com Use the product services link for product manuals. You can then choose tents. Or you can use this link:
http://www.coleman.com/coleman/images/pdf/2000000136.PDF
Posted on Dec 16, 2008
SOURCE: erect a tent
start with the two longest poles and feed them through (every pole is colour coded so you can't go wrong), that will give you the main shape. peg each corner, once done start with back door section and feed the shorter ones through the loops when done peg it down. then do the same with the other two sleeping sections. finally the front door section (the black/grey coded pole) the pole has a curve which positions in the middle,get that pegged down and put the guide ropes in and it tight. then you can fine tune the rest of the tent sections, once you have everything how you want it, then put guide ropes in. it takes 15/20mins with two people to get everything up, after that it takes 15/20mins for one person to fine tune. hope this helps, if this is your first time putting up the hartford xl it'll take you about 1hr 15mins cause it did me. but it gets quicker with practice.
Posted on May 18, 2009
SOURCE: No Instructions
Peg out the "brown" ground sheet of the inner tent and hold it up like a standard ridge tent.
Put the two shorter upright poles on the inside of the compartment (with something under the feet to prevent damage to the ground sheet). Put the 40mm tubes on the spike that pokes through, and then put the ridge pole on the outside.
Everything should then hold in place while you put the fly sheet over the top with the 2 longer poles at the front.......
tip - line up the seam on the fly sheet with the front of the inner tent as you peg it out....
Good luck
Posted on May 20, 2009
SOURCE: how do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Posted on Apr 08, 2010
vpsoccer
  • 269 Answers
SOURCE: I have a Coleman Savannah 6 tent but no
1. Usually you can go to the website of the manufacturer and get a sheet of instructions, or you can get them from a dealer.
2. Try it. You might find that it is obvious once you get it spread out. I bought one with no instructions once, and there was only one step that took a while to figure out.
3. Try a friend or neighbour who is an experienced camper. They might be able to figure it out pretty quickly.
Posted on Jan 26, 2011
Instructions on erecting an andre jamet 1967 super paiotte 1967 tent
Wow! That is not a new model. :-) All I can suggest is that you look for YouTube videos of setting up tents, or lay it out with a couple of friends who have a lot of experience with different tents and give it a try.
Aug 16, 2015 | Camping, Backpacking & Hiking
I need the inside measurements to see if 4 cots will fit inside.
This is a dog-gone big tent, even if the erected size works out to only something like 8x12 (leaving aside the screen porch) that will easily fit 4 cots 2x7 ft each. You are more likely to have problems finding tent sites large enough (flat) to allow it to be set up properly.
Apr 13, 2015 | Magellan Outdoors Yukon II Cabin Tent
Need instructions for putting up a tent please
I don't know what kind of tent you have but there are many videos on youtube.
erecting tent YouTube
building tent YouTube
making tent YouTube
Aug 15, 2014 | Sport & Outdoor - Others
What is a pop-up tent?
Pop-up tents are self-erecting tents that can be set up in under 2 minutes.
Sep 10, 2012 | Camping, Backpacking & Hiking
How do i put buzz lightyear tent together
If it is like mine (year, etc) you simply first lay out the ground cloth (if you have one) long-wise, then lay the tent body on top of the ground cloth. Next, stake out both ends of the tent (at head and feet of tent). Now put your poll sets together (the large one is for near the head of the tent, the short for the near foot of the tent). Go ahead and put the polls in the aligned grommets (matching the ground cloth grommets with the tent-body grommets). Once you have the two polls inserted, then clip your tent to them. Now, with your tent erect, Place your fly on top and drape over the tent accordingly; then fasten the fly to the tent using the belt-type nylon clips to do so. In this case the fly does not need to be "staked", rather "belt-clipped" together instead. That's it, your're done. Don't be alarmed if your tent floor seems as though it's lifting off the ground in some areas, this is normal. Just go ahead and put your bed role in the tent and prepare your area as normal.
Aug 08, 2012 | Playhut Disney Pixar Toy Story Buzz...
Hillary ten person family tent
Step 1 Choose a spot to set up your tent. Look for level ground that's free of large rocks or other debris. Make sure you're safely away from your campfire. If it's possible, pitch your tent away from your kitchen area as not to bring animals too close should they be attracted by the smell of food. Once you've chosen a spot, clear the ground of small rocks and sticks to give you a comfortable floor to sleep on. Step 2 Unroll your tent. Put the rainfly and poles aside. Open the tent body so it lays flat on the site you chose. Orient the door so it faces in an accessible direction. Step 3 Take out the tent poles. A basic Hillary tent will use two long poles for the tent body and one short pole of the rainfly. Assemble the two long poles and thread them through the pole guides on the tent body, attaching them to the holes in each tent corner to raise the tent. Step 4 Open the rainfly. Assemble the shorter pole and guide it through the top of the rainfly. Place the rainfly on top of the tent and secure it to the bottom of the tent body with the attached hooks. Step 5 Stake down your tent. You don't want to be surprised by a storm in the middle of the night or while you're away from camp. Stake your tent even if the weather is clear when your arrive. Use a stake at least in each corner of the tent. Find a rock to hammer them firmly into the ground.
Jul 24, 2012 | Sport & Outdoor - Others
Need instructions for setting up a Sears Edmund Hilary tent, Model 77015
Contact Hillary by Sears, Tent Service Centre 333 Yale Way, Fremont, CA 94538-6169 , USA , Phone: (800) 353-9180 or through their website: www.sears.com http://tinyurl.com/22movbx
May 25, 2010 | Rock & Ice Climbing
Cant setup my coleman montana 4 tent instructions in case flap are not good enough
Go to this site: http://www.meijer.com/catalog/product.jsp?productId=129522&parentCategoryId=221&categoryId=1082&subCategoryId=1312# : It has a video of how to erect and dismantle the Coleman 4 Tent.
Feb 02, 2010 | Coleman Montana Tent 6 Sleeps
Sport & Outdoor - Others Logo
69 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
