Question about John Deere Garden
My John Deere LA175 will not start It cranks and turns over and when I put some gas in the air intake it will run until it uses all the gas. Is it a safety switch or carb problem?
Any safety switches that will cut the fuel supply off?
SOURCE: john deere lt120 , 2004
my zero turn z5426 keeps moving on the left side even when its engaged in neutral
Posted on Nov 05, 2008
mowerman1857
  • 389 Answers
SOURCE: John Deere LA175 lawn tractor front wheel bushings
Remove the tire and wheel from the spindle. Take a long punch or similar item and reach in the center of the wheel hub where the spindle goes. Locate the space in between the inner and outer bushing and tap the edge of the old bushing until it comes out. Now go in from the other side and do the same with the other bushing. This one will be a little easier to do since you don't have to hunt for the center space. Put the new bushings back in the same way just be sure you drive them in STRAIGHT
Posted on Sep 18, 2009
  • 229 Answers
SOURCE: MOWER DECK BELT ROUTE FOR LA175 JOHN DEERE LAWN
you can try johndeere.com you should be able to find it there.
Posted on Oct 20, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
John deere la175 deck blades spin quit and fast. hook up to pto and engage engine boggs and tries to die
Maybe the travel speed is too high for it or the fusible link in starting circuit is blown.Check and adjust timing belt tension if necessary.Visit john deere expert or dealer.
Jul 21, 2016 | John Deere Garden
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
Why won't my Scotts brand John Deere L1742 start ?.
Check your fuel pump lines in right place
Apr 24, 2015 | John Deere Garden
How do you remove the gear at the end of shaft to place for it? John Deere LA175
It's a lock nut, but you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. Put a socket on the nut below the gear and ratchet it off. That's all there is too it.
Mar 29, 2015 | John Deere Garden
Will a John Deere LA175 lawn tractor start without the mower attachment installed?
I wouldn't think so. I know you DO need the seat switch depressed in order to start the engine.
Oct 18, 2014 | John Deere Garden
How to adjust the valves on a la175
that is a lawn mower number, not the engine. But if it's a John Deere LA175 and it has a Briggs single cylinder you need to adjust them to .004 ~ .006. As for how to do it. You need a manual because I am not typing all of that up
Sep 10, 2014 | John Deere Garden
La175 54 inch deck
Here is a belt diagram that I drew for a Deere LA175 (100 Series) 54 inch deck.
Apr 21, 2012 | John Deere 22HP VTwin 48" Riding Mower
My John Deere 318 lawn tractor runs while in neutral, but when I try to put it in forward or reverse, it dies. Any thoughts?
hello hird... you may have a gummed up carburator. get a can of starter fluid. get a helper. remove the air cleaner. start it up and leave it in neutral while your helper squirts starter fluid into the air intake for a minute. repeat if necessary until it no longer dies in gear.
if after 3 attempts check your mower deck as a frozen pulley wheel can cause this problem also. joe
May 15, 2011 | John Deere Garden
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
Jun 11, 2010 | John Deere 4020 Gas & Diesel Tractor...
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
65 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
