Corpus permobil c400 batterie manual
I don't know how to charge it
2 Suggested Answers
Vanguardian
  • 106 Answers
SOURCE: Battery on permobil will not charge
First off, a Permobil C500 is not a PC laptop. Next time, please put this in the correct category.
Try charging up the battery/batteries with a auto car charger. Make sure the voltage is set correctly, and charge it on slow or low, 2Amps. Leave it on there for about 4 hours and see if the chair will run and for how long.
This should tell you if its the batteries or charger that's bad.
Posted on Sep 25, 2012
Permobil c 500 remote plus esp programming power wheel chair
A servicing dealer has to program the chair. Permobil C500 Corpus Power Wheelchairs USA Techguide A lot of people have had problems with this chair.
Jul 28, 2017 | Cars & Trucks
My daughters wheelchair which is a permobil c400 will not switch back to drive mode out of the seat adjusting mode?
That mode button is defective replace it or the entire control stick is more likely what needs to be done.
Feb 23, 2017 | Drive Health & Beauty
Sep 25, 2012 | Computers & Internet
I have a 19 89 Chevrolet Astro Van and Veterans Hospital (VA) installed a 2'' hitch, and a Swing Away for the Harmar AL301XL Fusion Lift exterior Platform. All this is for transporting my Permobil...
check with your local auto parts store. They should be able to get you a shock called a load leveler. It will be a shock that has a coil on it. I have installed several of these on astro and safari vans to help with trailer towing. I know Monroe makes these and are the better shock manufacturer in my opinion.
They will look simular like this
Aug 05, 2011 | 1989 Chevrolet Astro Cargo
Would you be so kind as to send me the owner's manual- the little sheet that describes parts, directions, and so on. Also, we no longer have the charger for the battery. What does it look like? The...
Don't thank us yet!....So far we know it's ***********'s camera, *********** is elderly, you must be very nice to be helping her out this way, you can't find the charger, the batteries are ok but need charged. What don't we know?...what is the make and model of the camera?
Jul 27, 2011 | Cameras
My dell latitude c400 does not take a charge do i have to buy a new battery ?
Yes, most likely you may need to replace the battery. Try to get a different cell capacity this time (I do not know if you currently have a 6 cell or 9 cell battery). Once it's not keeping a charge it most likely has a problem.
Hope this helps...
Apr 18, 2010 | Dell Latitude C400 Notebook
How can I test if a battery for Dell Latitude C400 is working properly. I see the orange LED blink always when it is being charged, after it is unplugeed the system shuts off.
hello
You can check the battery by following the procedure written below.
  • charge the battery by connecting the charger.Look if it is showing the charging logo in the toolbar.
  • now remove the charger and go to screen saver option and select the power option.
  • there you will find power meter option.
  • it will show the battery logo.Now check the discharging rate of the battery.
  • this will tell you if tour battery is working fine.
thank you
Jul 19, 2009 | Dell Latitude C400 Notebook
When i power on my c400 the 3 green lights, light up and then it turns off. the battery is getting full charge. no sound comes from it. any idea what is wrong with it. I changed the ram thinking that could...
I don't know how old your system is but the battery packs have lifetimes that seem to vary from about 6 months to a couple of years.
I'm curious as to how you have established that the battery is getting 'full charge?'
The three keyboard LEDs are the start of the 'power-on self-check' and the fact that they go out again can mean that they are finished with the keyboard test and that the initialization is proceeding or that the battery voltage has collapsed.
If you don't own a multimeter (you should-they are cheap) I don't know how you know whether the battery pack is charged or not.
Battery packs can also fail without dying of old age; there is a thermal fuse in all of them that will melt open if the temperature surpasses a safe point (fairly low) and these Chinese parts are terribly unreliable and may fail just for fun. When this happens, they will not charge and in some, they won't produce any voltage at the pack's contacts either.
Feb 25, 2009 | Dell Latitude C400 Notebook
Dell C400 Laptop Battery not charging
Go into the battery properties and check if the battery is charging. If it says it is, then test it, use the battery to see if it really is charging, they will sometimes give a false reading. If it's not charging, then check the power supply with an ohm meter for the proper output. If this all checks good, but the battery isn't charging, then I'm afraid you have a failed power management system on the motherboard. The power management system controls the charging along with other power related aspects of the machine. If the power management system has failed, then unfortunately, you will have to replace the motherboard in order to fix it.
Aug 12, 2008 | Dell Latitude C400 Notebook
Dell Latitude C400 PC Notebook
yes the power jack need to be replaced or your power adpoter maby no good any more more likley teh power jack all dells have these heat isses
Jan 23, 2008 | Dell Latitude C400 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
