Question about Delta Enterprise Versailles 4970 Crib
I need screws for graco model no.3620235-053 - Delta Enterprise Versailles 4970 Crib
I was given a graco crib wooden for my grandbaby but I don't know what size screws to get because it didn't come with any can you help
Fixya does not sell replacement screws. Because this is a safety issue, the hardware recommended by Graco should be used.
Jul 21, 2017 | Graco Baby Gear
2002 Graco crib instructions . i bought a used 2002 crib and I need to know how to put it together.
ok first thing first ,  some graco cribs and other products from 2002 -2010 are being recalled , so what crib model do you have? second , putting together a crib is very easy , . First , take the head board and stand it up , next find the side railings and one by one put the screw thru the rail and into the headboard , hold it in place untill it is where it needs to be , then put the second railing on , the screws should go thru the rail and into the headboard with the headboard in back of the rails, after the rails are secured then hold the foot board in place untill the screws are fastened into the rails as well , after you do this , then go around and make sure all the screws are tightned, then take the mattress spring and place it inside the setup rails and screw it unto the places alotted for the screws , then after this , place the matress inside and your done....if this doesnt help , please email me at konmon52@aim.com and tell me which model it is
Nov 19, 2010 | Graco Baby Gear
Need a graco car seat model ##7F07EMA3 replacement parts
Hi, you can get Graco replacement parts at the Graco website:
http://www.gracobaby.com/replacementparts/Pages/ReplacementParts.aspx
You'll just need your model number and either the serial number or manufacture date, and then you can browse through the available parts.
Apr 06, 2010 | Graco Alano Travel System Emelia 7F07EMA3...
How do I remove seat cover on Graco Duoglider
there are tabs with screws holding them in place unscrew them and youll be able to slip the seat covers off.
Mar 17, 2010 | Graco DuoGlider 7924 Twin Seat Stroller
Graco 6K00MTR3 Fabric Attachment
jhonkrell, try to check it here:
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
Just enter the model and serial number of your stroller. Hope it help your problem.
Feb 08, 2010 | Graco Quattro Tour Kentshire Stroller
I need screws to put this crib together. Graco
Take one of the screws to homepot,and look at the threads on it!!You should be able to find something close to that screw!! If you don't have any screws than try to come slose to what it look like!!
May 15, 2009 | Graco Ultra Deluxe 5-in-1 4605 Crib
Crib instructions for the Graco Apsen 3-in-1 8740 Crib Problem:
PLEASE READ THIS WEBSITE INFO ASAP! The model 38740 WAS RECALLED! Please check your serial number with this wepage! http://www.consumeraffairs.com/recalls04/2007/simplicity_cribs2.html
Also, you can call Simplicity Inc, who made this model with Graco at 1-800-858-8323. If your model is not recalled, I'm sure they can instruct you on obtaining a manual and parts needed! Good luck!! :)
Jul 26, 2008 | Graco Apsen 3-in-1 8740 Crib
Graco pack n' play...I can't get the vibrating/musical attachment to work
The main unit also takes 3 AAA batteries.  For the model I have you need to remove 2 screws to get to the battery compartment.
Jun 26, 2008 | Graco LeisureSport 7420 Jogger
Delta Enterprise Versailles 4970 Crib Logo
200 people viewed this question
Top Delta Enterprise Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Delta Enterprise Baby Gear Expert? Answer questions, earn points and help others
