Question about Canon D1250U2 Flatbed Scanner
Need to communicate with Samsung printer CLP300
How to get my Canon F916000 to communicate with Samsung Printer CLP-300
  • carmoney Mar 12, 2009
    XP is right
    Brigadier General:
  • Canon Master
  • 3,614 Answers
You must install the canon driver on your PC
if you havent the driver cd, download it HERE & HERE
for the Quick Start Guide manual
Posted on Mar 12, 2009
  • 564 Answers
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
  • Prem  Kumar
    Prem Kumar Mar 12, 2009
    • Unplug
      the printer cable from the computer.
    • Unistall the
      printer drivers from Device manager and also unistall the all the printer
      appications
    • restart the
      computer
    • try to download
    • after installing
      drivers and software it will ask you to connect the printer.
    • then you can
      connect the printer and and try to Print the test page.
    PREM
  • Canon Master
  • 13,433 Answers
If you want to print directly from the scanner, then both need to be fully installed. and the clp needs to be set as the default printer. both need to be turned on. Then it should print. If not then I would suggest to scan to computer and print the scan.
which version of windows your using? xp?
    Top Expert:
  • Canon Master
  • 77,202 Answers
Have u gone to the Samsung web site and downloaded the latest software for your operating system for your printer?, the problem is most likely the printer and not the PC
What weight of paper will the CLP300 take? For example 160gm is this possible.
The specifications for the CLP-300 say it should take paper of 60gm to 163gm but in practice I have found that 160gm is too heavy and will not feed through as is too stiff.
Sep 11, 2011 | Samsung CLP 300 Laser Printer
MY SAMSUNG PRINTER CLP300 IS NOT LOADING THE PAPER AT THE TIME TO PRINT HOW CAN I RESOLVE THE PROBLEM?
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 13, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Printer
smasung clp300
just clean toner weast chember and also drum unit.
sometime if u user refilled cartridges after use this u have facing this porblme.
pl do this it work perfect.
www.howtorefill.com
Jun 02, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
May 11, 2010 | Samsung CLP 300 Laser Printer
Samsung clp-300 Error message is "fuser low heat error
The problem is that the Fuser is not heating up. Its possible you have a broken heat lamp.
The Fuser will have to get replaced, if you want to spend less but more labor, the heat lamp can be ordered.
Mar 07, 2010 | Samsung CLP 300 Laser Printer
How to reset printer counter samsung CLP300
There are two major counters in this samsung CLP300 color laser printer.
I will give you the answers for both.
The standard one is the page printed counter.
You can not change that
The only way is to change the system board or get an used printer
(AS LOW AS $80 now!) and swap it.
The other set of counters are the toner counters.
eBay seller tpstock6898s.gifhas them
Set of Samsung CLP 300/CLX 3160FN reset Chips
eBay Item number: 260468470362
http://cgi.ebay.com/Set-of-Samsung-CLP-300-CLX-3160FN-reset-Chips_W0QQitemZ260468470362QQcmdZViewItemQQptZBI_Toner?hash=item3ca521725a&_trksid=p3286.c0.m14#ht_790wt_1165
You can pick up the whole 4 chips set to reset the data to the printer for under $10.
Please post more information on what you like to reset.
I will follow up on this post.
Aug 29, 2009 | Samsung CLP-300N Laser Printer
Samsung printer
go to samsung website,under support and downloads,type clp300,will get drivers
Nov 20, 2008 | Samsung CLP 300 Laser Printer
Samsung Printer CLP300
Have you run the Dr. Printer utility that comes with the printer? If not, run that and see what it says. You can download it from the CLP-300 support page at samsung.com.
Apr 30, 2008 | Samsung CLP 300 Laser Printer
Canon D1250U2 Flatbed Scanner Logo
76 people viewed this question
old marine
old marine
