Question about Canon Mg8150 Wireless Mfc
Canon mg8150 error 5030
Error 5030, wont start blue and yellow lights flashing
komguy
  • 2306 Answers
SOURCE: Canon MP980 All in one printer - Error 6000
Error 6000 tells you that the paper feed roller is not turning, check for any foreign oblects in the paper path, a flashlight and small mirror is the best way to look.
Posted on Jun 19, 2009
SOURCE: error 6a00
I found numerous suggestions on FIXYA for other Canon printer models with the same 6A00 error message. The isuggestions mainly zero in on the purge station where the printer head parks and possible cause being bits of jammed paper at the two pieces of sponge material. There were several reports of cleaning the two sponges at the purge station and the problem going away after. I checked my printer but did not finad any jammed bits of paper. But I found the purge station was a bit up and could be pressed down - probably a bit sticky due to the soaked sponges and not returning to its original position. After that I didn't get the error message anymore. The two sponges on my printer purge station were black and possibly soaked with ink and I am thinking of cleaning these the next time.
ur flashing lights also seem to be a cnsequence of this....
hope it helps.... good luck
have a nice day
Posted on Jul 08, 2009
pineworks
  • 4041 Answers
SOURCE: Canon i250 printer problems
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...
Posted on Feb 25, 2010
sfigurasin
SOURCE: Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Posted on Mar 31, 2010
  • 332 Answers
SOURCE: canon mp510 green and yellow
ggogle "which lights are flashing" for your answer
Posted on Jun 27, 2011
Mg8150 printer not responding. checked all connections and printer has all appropriate lights on
Have that started recently or have you just bought/connected it? If the latest is correct you need to install drivers for your printer that you can download from the MG site.
Feb 19, 2015 | Canon Mg8150 Wireless Mfc
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Flashing green and yellow lights
You need to count the number of flashes to diagnose the error. Then go here and type error lights in the search box. You';; be able to follow the appropriate code to a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | Canon iP100 Portable Printer
Canon Pixma MP750 Printer
try to reinstall the printer cartridge
Jan 15, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Canon Mg8150 Wireless Mfc Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
