Question about LG Televison & Video
Lg tv doesn't recognize antenna connection - LG Televison & Video
4 Suggested Answers
akartsb
  • 68 Answers
SOURCE: I have the lg dvx640
If the cable does not fit and you are not getting sound when plugged in. It is most likely the cable. Check the pins to see if they are in-tact and are not bent or worn. If you have a spare, try that. If you can plug the cable into another tv and it works then... back to the drawing board. Post back and let us know if the cable is not the problem.
Posted on May 23, 2011
SD Tech
  • 14553 Answers
SOURCE: A GPX model tvwb534 connecte to an indoor rabit antenna doesn't work?
You either may have the set on Cable setting or the signal is too weak for the set to pick up the channels---indoor antennas have a very limited range and many channels have ended on air broadcasts completely
Posted on Mar 24, 2012
  • 155 Answers
SOURCE: I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Posted on Oct 29, 2012
Testimonial: "That's what I thought - thanks! "
I am trying to setup a new lg tv but it will not recognize my satellite channels
When you are setting up your remote, make sure it is on Satellite and not on Antennae or Cable mode. Good luck
Jan 03, 2017 | LG Televison & Video
My LG Television does not recognize local over-the-air stations.
somewhere in the main menu it asks for input . that needs to be set to antenna or air .once you find that and put in the right kind of input then do the autoscan.
Jan 24, 2015 | LG Televison & Video
Why do antennas become out of order
Poor connections between the antenna and the wire that connects it to the TV is the 99% reason. The other 1% is improper direction when aiming the antenna.
Jul 16, 2014 | LG LN530B 32LN530B 32IN LED LIT 720P 60HZ...
Oct 29, 2012 | Televison & Video
Mar 24, 2012 | Televison & Video
I installed a coby tv in my RV. Auto scan worked great for a year. Today it picks up no channels at all. Everyone else in RV park has 20+ channels. The scan performs everytime, but picks up nothing
If you've tried all positions with antennae, booster switch is on, and are sure you have all settings on TV correct, try running an alternate cable directly from antennae head to back of current plate where your co-ax from antennae is attached. That will tell you if you have a bad cable or connection from antennae to plate inside. Just get a piece long enough to go through door or window to current spot where connected. If that doesn't cure it, then it's a head or booster switch problem. You can even by-pass the booster and go direct to TV to see if any better.
Sep 03, 2011 | Coby TFTV3227 32 in. LCD TV
We have a 22" samsung
Hello idmcintyre,
Don't worry, all you need to do is get a digital converter box. You can get one at most electronic stores, especially the ones that sell TV's. Remember that you still need your antenna. Your antenna needs to hook up to the converter box, and then the converter box needs to be connected to your TV. The converter box just changes the signal. I hope this helps, give me a feedback if it doesn't. Good luck.
- Joe
Aug 31, 2011 | Samsung Televison & Video
Does it need a special antenna? I don't have cable or a dish. 3 stations didn't come in so I manually programmed them and still no luck. What to do?
You can buy an indoor antenna or you can mount one on your roof top. Find auto programm in the setup menu of the tv. Select antenna not cable and select auto program. The number of stations will depand on location. You may have to rotate the antenna. If this doesn't get you more than 3 stations you may have a tuner problem and need to replace the main board in the tv.
Aug 30, 2011 | LG 32 32LK450 32 in. LCD TV
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
My BRAVIA KDL-46XBR3 shows like a mirror image below whatever is being shown
many bad lcd panels will show issues like this
check the menus and if theyre bad its likely a bad lcd panel
i'd complain to sony and see if they are extending the warranty for this issue as some xbr panels were defective
May 22, 2010 | Sony BRAVIA KDL-46XBR3 46 in. LCD HDTV
Televison & Video Logo
105 people viewed this question
