Question about HP VP6220 Multimedia Projector
New bulb in a hp vp6220 projector
I have fitted a new bulb and followed the instructions to reset the bulb counter by pressing and holding the 'up' button for over 5 secs but I do NOT get a counter display.
  • Anonymous Apr 14, 2009
    I didnt fet one either ,also my projector still fucntioned after 3000 hour on the old bulb so I got a new one and I am having the same problem it will not reset hours ??
We have a number of these at the school I provide support at and just recently I've had to replace the lamps in six of these.
I've found the method HP details a bit hit and miss, i.e. you might have to try doing a few times before you get the message. First power off the projector and then remove all inputs to it, it won't work if you have anything still plugged in other than the power. Re-apply the power and then press and hold the up button. You should now get a message on the screen 'reset lamp hours for new lamp - press [auto sync] to reset', press the auto sync button as soon as you see this message as it soon goes off.
You can then check via the menu to make sure the lamp hours has been reset to zero.
Posted on Jun 22, 2009
Cannot reset lamp counter on benq mp620 projector, projector bulb has been replaced but lamp counter warning is displayed on startup and requests buld change and reset of counter. So I'm stuck in a...
Hi, I don't know if this is to late but oh well, hold down the exit button on the projector panel for 5 secs, and then press auto on the same panel after, this should reset the hours back to a lovely zero
May 26, 2011 | BenQ MP620p DLP Projector
I just got a new bulb for my projector. it was fitted as per the instructions, and looked undamaged on delivery, but after about 10 min of viewing, the hight temp alarm sounds and the projector shuts...
Did you rest the lamp hour after replacing the lamp. It is recommended the you have to reset the lamp hour after replacing the lamp. For resetting the lamp hour do the following.
1. Power ON the projector
2. Press the Menu button
3. Select OPTIONS
4. In OPTION menu select Lamp Reset and press the enter button.
(If the lamp hour counter is at the heights level then the projector will turn OFF after some time.)
Apr 28, 2011 | Optoma EP1690 DLP Projector
Instructions on changing bulb
Turn off the projector, unplug the AC power cord, let it cool for 45 minutes.
remove the screw that holds the lamp cover on.
remove the 2 screws that hold the lamp in. lift the lamp out by the handle.
replace with new lamp and do the reverse.
reset the lamp counter.
press the menu button.
go to setting menu, then to lamp counter, press select button, select reset, select YES. then YES aqain.
Apr 06, 2011 | Sanyo PLC-XT25 LCD Projector
How can you view the amount of bulb hours for an Eiki LC-986?
The manual for your projector is found here:
My assumption since it is not specifically stated on the location of the counter is it should be located close to the option to reset the counter. I would start here and look around above and below this option.
According to pg 39 the steps to reset the counter are the following:
Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to
move a red frame pointer to SETTING Menu icon (refer to page 37).
Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button.
Message "Lamp replace counter reset?" is displayed. Move pointer to [Yes] and then press SELECT button.
Mar 03, 2011 | Eiki LC X986 Multimedia Projector
Can't reset lamp timer for new bulb
when you replace old lamp with new one the lamp timer not reset automatically the counter is a software data and you reset manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
Feb 10, 2011 | Sony VPL-ES2 Multimedia Projector
New lamp fitted to a 6121 uint but it says replace lamp as life has reached more than 2000 hours
Follow the procedure in the manual, as this counter needs resetting too. There may be a reset button near the lamp or cover.
Sep 02, 2010 | HP VP6121 Multimedia Projector
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
LP130 projector - no light from lamp
there are several other issue that can arise with this unit
you may want to check out
Jun 30, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
LP 530 Lamp does not power on
Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
hope this helps... Regards Vortash
Feb 27, 2008 | InFocus LP 530 Multimedia Projector
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
HP VP6220 Multimedia Projector Logo
437 people viewed this question
Ben Johnson
