Question about Watches
Dufa grandfather clock not working
Stops running after 15minutes
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Posted on Mar 23, 2009
small6363
  • 18407 Answers
SOURCE: grandfather clock pendulum keeps stopping Clock is fully wound. How to check& fix issue?
click the link below for help
http://www.youtube.com/watch?v=ps6dPxoxe9c
Posted on Sep 05, 2012
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
    Hi Pam,
    I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
    Howard Miller Grandfather Clock
    Dec 06, 2016 | The Watches
    Polaris grandfather clock runs slow need to adjust time up
    Nov 17, 2012 | Watches
    Edward Meyer 31 Day Grandfather Clock manual
    I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
    Jan 23, 2012 | Watches
    Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
    Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
    Jan 01, 2011 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    The pendulum stopped swinging...the clock and chimes work well
    Hi
    This clock short of needing a full service may simply be out of beat.
    Taken from my web page located at:
    http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
    "HOW TO PUT YOUR CLOCK IN BEAT"
    -Included below is a 10-second sound <snip> of a clock both in and out of beat.
    IN BEAT ////////\\\\ OUT OF BEAT
    · Turn on your sound and click on the clocks above for a sound clip.
    -One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
    -I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
    -As I'm sure we now realize a clock must be in beat but not always level to function properly.
    · Above is the verge with a slip clutch.
    · Often found on Grandfather clocks and requires only a long swing to get it in beat.
    -To get the clock on the right side in beat you would need to push the verge assembly to the left.
    -If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
    R/ David
    Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Clock cleaning
    This is not as easy as you might think. We learn decades to repair (cleaning included) watches and clocks. Any tip would be with no use, as every clock needs individual and specific attention.
    The only tip is: visit an eBay and buy the clock repairers book. I've seen some books there.
    All this is under the ''Jewellery and Watches'' section.
    Mar 27, 2009 | Watches
    Mar 23, 2009 | Watches
    Watches Logo
    81 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
