Question about Innovera Ivr62204 - Mini Wireless Optical Mouse
Install instructions for ivr-62204 - Innovera Ivr62204 - Mini Wireless Optical Mouse
How to Find an IVR Supplier?
You really need to talk to the experts on this subject so follow the ink. Hosted IVR Solutions
Oct 18, 2016 | Cell Phones
After changing the battery on my innovera mini optical mouse IVR 62204 it is no longer connected to my computer
Are you sure that the new battery was a good one? If it is ok, change USB slot. If still not working, you've got some problem with USB dongle or the mouse. Generally, "mice", even wireleess are "disposable". If you have warranty, should take it for "service" and they shuld check problem and replace part. If no warrant, your only choice is to get a new mouse.
Oct 09, 2014 | Innovera Computers & Internet
How do I stop my IVR-16010 from rounding off my answer?
This makes zero sense, but you must press the "tab" button. Also I know this is two years too late, but no one has answered this question online and someone might find this helpful.
Aug 16, 2014 | Innovera 16010 16010 One-Color Printing...
Needles on my Gauges are absolutely crazy! 1996 Pontiac Grand Am SE V6
1= this happen because th IVR fail, see the diagram and test it use the DVOM OR VOM for test the IC .l
2= test the thermistor or sensor for defective.
3= if the voltage of IVR is out of regulation in this case +12vdc,test for ground.if is o.k test by the side of battery side of the IVR, if this voltage is present replace the IVR, if regulated voltage is withing specifications, test the printed circuite from the IVR to the gaues, and if there are open circuite replace the circuit board. OF course test the fuse too.
God bless you
Jul 14, 2012 | Cars & Trucks
I have an Innovera IVR 16015 calculator and need instructions on how to change date and time
I have an IVR-16015 calculator on my office desk. I too was looking for instructions on how to set the time and date and found this site. The previous information is wrong. I just discovered how to set it... The switch needs to be set to "ON", then press and release the blue "TIME" button to toggle between displaying the TIME or DATE. Depress and hold the "SET (=)" button for about 3-seconds to enter edit mode then use number keys to modify the displayed value. Depress the "SET (=)" button to save input and exit the edit mode. Pretty simple when you have the correct instructions, huh? By: The Fox
Mar 21, 2011 | Office Equipment & Supplies
I HAVE A VIDEO WITH AN IVR FILE, I HAVE NO ENGINE FOR IVR FILE, I HAD TRIED DIFFERENT COVERTER BUT NONE OF THEM SUPPORT .IVR FILE. PLEASE ADVICE
.IVR Files are a "Video format developed by RealNetworks for sharing video clips on the Web; may be created by using the "Record" feature in RealPlayer 11 or later; saved in a proprietary format that can only be opened with RealPlayer."
Basically, Real converts these videos to .ivr files so that you don't use other video players except Real to view them, and so you'll pay Real for a subscription to be able to convert the files. If you actually right click on the .ivr files in your Real Library there will be an option saying "Covert Media Format..." and if you click on that it will tell you you have to upgrade to Real Player Plus in order to convert.
There is a work around i found while googling, you can also burn your files to a dvd or video cd and then rip them back to your computer and they'll be in another format. The downside is that this can take more time if you want to convert a whole lot of files and you have to have dvd's and cds at your disposal. but at least it works.
Hope it Helps!
CreativeTTECH
Nov 24, 2010 | Computers & Internet
How to convert .ivr file to .mpeg file. conversion softwear free version web address.
hye sankar
how about you try to use 'total video converter'.. for me, it was the best! let's try this...may be it can help to solve your problems. download and install Total Video Converter Version 3.11 and you have to register to get registered version. After install, open, go to 'About', click 'Register', then Input or Paste the registration code. Use this registration code to use registered version (full version): 0ab52023-ba00347e-9fa86acd-fdc330a9-68578b7e-264b81e1-30bdfeef-cea403fa-20457e4a-39c03409-f69a9aba 388e8a94-677044c7-643fe9ac-66523c91-18a61801. You can convert any files as you want, there have many options there. You also can burn files to cd/dvd. Hope it was helpful!
All the best!!
Jun 03, 2009 | Microsoft Computers & Internet
How can i develop IVR System using java,send me some sample code
you can find out code along with detail here
http://www.codeproject.com/KB/java/IVR.aspx
Mar 30, 2009 | Computers & Internet
Java code for IVR system
dear friend check these websites:
http://www.java2s.com/ http://www.sun.com/
You can get your answers about java there. Goodluck
Jan 22, 2009 | Cisco IPCX OR IP IVR 3.5 3.Y MS SQL SVR 1...
Audiocodes MP118 8 FXO early media to Freeswitch SIP extension
Hi, man.
There are many things to consider in this type of application.
when calling from PSTN to IP using analog lines from time to time you will have this type of event, I suggest working with H323 protocol, this will tone down a bit your problem.
If you want optimum performance, you should use a DID with the channels you need and address to your PBX SIP FreeSwitch. The DIDs are cheaper and are digital which eliminates random connectivity problems in the incoming call.
Once you have directed the DID you tell your server to transfer the call to the IVR using your internal dialing plan.
Lucky
Oct 06, 2008 | AudioCodes MP118 Analog Modem
Innovera Ivr62204 - Mini Wireless Optical Mouse Logo
80 people viewed this question
Top Innovera Computers & Internet Experts
Foxgrove
Level 1 Expert
Timothy Gore
Timothy Gore
Are you an Innovera Computer and Internet Expert? Answer questions, earn points and help others
