OUT OF CONTROL
I can't control the mouse, I move it but it don't go sraight to where I try to lead it looks like it's drunk, it's a real bummer now working with this, bought the mouse several months ago, this problem started this week, it's so tyring using it its so difficult and somehow imposible to move it freely and easily, it's drunk
sorry, I'm not English natural born speaker
mouse model Targus AMW1601EU
    Problem Solver:
  • 17 Answers
OK. So lets start from the top. This problem could be related to software or hardware. The easiest way to decide this is by plugging the mouse into another pc if possible. Although the first thing I would try is replacing the batteries with it being battery operated. Also ensure that the optical eye on the bottom of the mouse is unobstructed. Some optical mice also react odd when used on different surfaces, it is always best to use a mouse pad. Lastly if none of this changes the operation, you may want to reinstall the provided software.
http://www.targus.com/UK/product_Details.asp?SKU=AMW1601EU
Posted on Mar 14, 2009
I don't have a credit card, how much for the fix?
you need to go to your control panel open your mouse and adjust your settings there. click the lower left START to open dash on the right after it opens select CONTROL PANEL when open scroll down to mouse.
Apr 07, 2012 | Computers & Internet
I have a gear head mouse, it's a lighted optical mouse model no OM3500U and I can't figure out how to change the batteries to see if that is the problem with it. It won't work at all and it...
There are no batteries in this mouse as it is a wired mouse. Wireless mice require batteries, not wired.Try removing the mouse from the USB port it is in and move it to another available port. It should work right away (after it detects the new device)but you may need to restart the computer after you move it to the new USB port. If that does not work, than it died.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Computers & Internet
Mouse does not work, wheel keeps flashing fast, for few second and stops. Each time i try to move it, it acts like that
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port ((if applicable))
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click you will have options to update driver software disable uninstall scan for hardware in xp changes and properties
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall also
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 arrows then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
hope this helps
Apr 18, 2011 | Computers & Internet
I have a dv4000 (dv4272us) and when I'm typing, periodically i must be brushing the touchpad because the cursor moves someplace else and begins typing somewhere else on the document. I using windows 7 and...
You should be able to disable the touchpad from the CONTROL PANEL - MOUSE options.
Go to Control Panel, click Mouse, click the big pointer, click Device Select, look under Touch Pad, click the blank "dot" next to Disable, also checkmark the box next to Disable touchpad.
Click APPLY and OK, then Restart your computer if necessary.
Apr 16, 2011 | HP Pavilion dv4000 Notebook
My pen is not acting correctly. It is sticking to icons I want to move but not letting them drop. Please advise that would be great! Many thanks. Kerry.
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
it sounds like a mouse problem
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
click start control panel,mouse you can speed up the mouse
also under pointer options you can speed up the mouse you must click apply after you have made any adjustments
hope this helps you
Feb 25, 2011 | Computers & Internet
My Trust MI-4150K mouse doesnt move anymore. I've tried to change battery, changed port usb of the receiver, changed PC and still doesnt work. please help. It may have something with the reset button.
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty or you
make sure you have the correct mouse selected control panel mouse hardware
might have to uninstall the drivers then reinstall the drivers
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Dec 03, 2010 | Computers & Internet
Mouse cursor gets caught in corner of screen and won't move even with mouse movemenet.
make sure you have the mose selected control panel mouse hardware
in xp
hope this helps
Dec 01, 2010 | Computers & Internet
MY LAPTOP START REAL SLOW. SOMETIME MY MOUSE DON'T WANT TO CHANGE TO OTHER SITES. AND IT MOVES TO SLOW. CAN YOU HELP ME?
you might have to many programs loading at start up or you might have a virus run your antivirus program looking for a virus then
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
as for the mouse if the first things i mentioned that you do does not fix control panel mouse you can speed up the mouse and under pointer options you can also speed up the pointer
hope this helps
Nov 15, 2010 | Computers & Internet
Does not move cursor, some times it moves but no control
You don't have to take it apart to clean it. The ball is designed to be removed from the unit by releasing it from the bottom of the control. Then you just simply clean off the red area with a cloth. Do not use alchohol on the surface. It could damage the unit.
Feb 17, 2009 | Logitech Cordless TrackMan Wheel Mouse
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
