Question about SanDisk Sansa E280 MP3 Player
MP3 player short play time
This MP3 player gets quite warm durring use, and runs for 2 hrs., more or less. New batt didn't fix prob. Doesn't always fully charge, I think. My first MP3.
  • 5 more comments
  • Tom Hubisz Mar 12, 2009
    What does battery over complete mean and does the heat generation cause the battery to die sooner?
    Didn't fully understand the first solution. Sorry
    Warantee is no longer in effect. Sandisk couldn't help.
    Battery has been changed. problen persists.
    changing the batt did not fix prob
    The replacement was generic, the original is OEM. I've reinstalled the OEM and will run it through some cycles. That didn't work before. anyone have an unconventional fix, or a mechanical repair?
  • Tom Hubisz Mar 17, 2009
    This solution is helpfull. Hope I can do the repair/have it done. Thanks, Tom
  • SanDisk Master
  • 19,396 Answers
Re: This MP3 player gets quite warm durring use, and runs for 2 hrs., more or less. New batt didn't fix prob.
the unit is defective and will be replaced at factory expenses. The fault is probably a small short somewhere in the battry charging circuit.
See SanDisk Contact Us
Posted on Mar 12, 2009
  • Ginko
    Ginko Mar 21, 2009
    Let us know if the repair had been successful.
    Many thanks.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Opening these would not be a good idea. Infact you cannot fix them my opening.
This particular model of Sansa has troubles often with many users. Even updating firmware may not work.
I had the same model and same problem.
Only thing I could do was to return it.
If you cannot return this or if you cannot use the warranty, You may want to try with different firmwares versions.
    Genius:
  • 1,550 Answers
It tends to be short circuit inside the player . The main chip is short and it tends to draw more power from the battery and thats reason your player is getting discharged soon . It is internal problem .
You need to take to service center to get it repaired . But the cost involved is more if it is main chip needs to be replaced you can better go with new player rather than spending money in it .
    Brigadier General:
  • 5,158 Answers
There is a capacitor that has failed... basically it's called leaking... it cause heat and shortens battery life... not sure you can repair those as a computer solders the parts on... they are very tiny
  • 412 Answers
Its a battery problem....
Change the battery...
  • 6,784 Answers
Hi, there may be some circuit board issues here. that heat and run time seems to be a bit abnormal. if you have a warranty or, the purchase of this unit was recent, i would return this device. It seems to be defective. you should be bale to exchange this with no problem. i have the same mp3 player and it rarely becomes hot or heated. Maybe luck warm but, not hot. there is defiantly a defect present in this unit.
  • 2 more comments
  • Michael Masters
    Michael Masters Mar 12, 2009
    That means the battery has been overcharged. this can damage the cell and the internal components of the system.
  • Michael Masters
    yes, it will kill the battery if its overcharged.
  • Michael Masters
    Assuming that this overcharge didn't ruin the board, you can insert a new battery but, remember to watch for the batteries charging cycle to end and take it off the charger before it becomes overcharged.
  • Michael Masters
    ok, if the problems still there, the overcharge has damaged this device. if the warranty is not available, you will have use as is or, you can cut your loss and purchase another unit. im afraid this unit it permanently damaged.
  • SanDisk Master
  • 13,433 Answers
How is warranty and did you contact sandisk about this already?
  • 564 Answers
Let the battery get over complete and remove the battery then connect the battery and charge it full and try to use it
dont connect the power card and during use
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
    Brigadier General:
  • 3,614 Answers
just do a complete cycle of charging and discharging the unit.
  • 2 more comments
  • micromaster
    micromaster Mar 12, 2009
    full discharge the unit before charging it again.
    do this cycle at 5 time recharging & charging state
  • micromaster
    is the battery of the unit has already been replaced and change?
  • micromaster
    1. let the unit/battery discharge before charging it again.
  • micromaster
    check the battery terminal and the battery was properly sit and connected, be sure that there were no other contacts to it
    Top Expert:
  • SanDisk Master
  • 63,456 Answers
Did u use a Generic battery? if so get the OEM sandisk battery.
  • yadayada
    yadayada Mar 17, 2009
    there is no "mechanical fix" for your MP3 player, but don't use Generic batteries, they have very short run time, there is a reason why the OEM cost so much. Your issue is the poor quality aftermarket battery.
I charge my player and it says full battery but when i turn it on, it plays 2 songs and then says low battery and shurs down
hi.. if you carefully check your battery if there's
a depleted side or bulgy appearance...if yes try to buy a new battery.
also observe the charging time in idle mode..( don't use it during charging)
and if it can only be use or short period of time..I strongly recommend you
to buy new batt...pls. rate and vote...good day...
Feb 17, 2011 | RCA OPAL M4001 MP3 Player
All it says is www.appleipod.com/support/ipod and says low battery and does not turn on
It's possible that the internal battery simply will not hold any charge (or is partly shorted, meaning it prevents operation even when plugged in -- you tried that, I assume). Anyway, the batteries on these units can be replaced by the user (with a little bit of skill) and you should be able to find batteries online for less than $20. If a new battery fixes it, you're all set, otherwise, you could always sell that new battery to someone else. I've done this with all of my old iPods and they play for two or three times longer than when they did new!
May 21, 2010 | Apple 20gb Ipod Mp3 Player With Click...
16gb Sansa player that recharges and plays for only 3-4 hours
let your battery run out by leaving you mp3 player play as long as it can....then open up the back of the mp3 player take out the battery and put the battery a freezer for an out or 2 then let it sit out for a day then put it back in the sansa and recharge it and it should either fix it or help add more life span to the charge
Jun 21, 2009 | SanDisk Sansa e260 MP3 Player
The inner screen is broken
to fix it is free if your guaranted time is not over. But if it's over, fixing LCD is more expensive than buy a new one.
May 13, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Inverted Display, faded, and screen goes blank
if you let it get to much direct sunlight might make it do something similar to that
Jan 05, 2008 | RCA TH1101 MP3 Player
Not turning ON
Hold the play button down for 5 long seconds then release and wait , red light should come on. th en hit play again to play.
Jan 02, 2008 | Coby MP-C582 MP3 Player
Charging
If it just has a usb cable for charging then yes you would. The charging time varies but it generally shouldn't take longer than 3 hours to fully charge. Check your manual if you have one, it will give you more information.
Oct 24, 2007 | Audio Players & Recorders
Few Problems
I'm not sure about your other problems but i have the same problem as stated in number 2. I'm not quite sure why that happens but if you use music match it will show all your songs in a list
Oct 23, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa E280 MP3 Player Logo
119 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
