Question about Hitachi 55FX48B 55" Rear Projection Television
Will not power on......what could be the problem on the board?...i am good at soldering things...will replace if I new what to replace
Won't power on ......electrical strorm the other day
  • bwshields Mar 22, 2008
    50"rear projection won't turn on. No storms or anything. I just unplugged it and moved in to a different room and it won't turn on. And yes the outlet is good.
    Genius:
  • 1,153 Answers
If have already unplugged and waited for atleast 15min. and still no success. Then only if you are Electronicly inclined. Check to see if you get dead completely or you get an indicator light momentarly. Which these are two different symptoms. first dead no indicator. check R931,E994,Q777. Then if indicator light comes on and goes off, check E994 which is fuse opening, C707-1000pf 2kv cap, also check D915, I601, IK04, and 05
Posted on Aug 16, 2007
SOURCE:
Broken oximeter
May just need to purchase a new one to be honest, not a lot can be done.
Jun 25, 2013 | Medical
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dash shuts off while driving a 2005 mercury mountaineer
Do you know anything about testing automotive electrical system's ? What a wiring diagram is an how to use one to find testing points in a electrical circuit ? Do you know what encompasses a automotive electrical circuit ? Power B+ side ,ground side , load or componet ? How to use a DVOM - digital volt ohmmeter . Voltage drop testing ? Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click body & accessories ,then under subsystem click instrument cluster . Watch these videos
Electric Testing Techniques You Need to Know
Nov 01, 2017 | 2005 Mercury Mountaineer AWD
1990 Accord electric windows won't close
If you own a Honda Accord, you know they rarely give any trouble. ... My 1995 Honda Accord Window Won't Close ... are a bundle of complicated electronics, lots of wiring and more computing power than the average computer from 1990. That ...
http://www.ehow.com/how_4520901_fix-power-windows-honda-accord.html
Read more: 1990 honda accord electric windows won't close ' eHow.com http://www.ehow.com/search.html?s=1990+honda+accord+electric+windows+won%27t+close+&skin=corporate&t=all#ixzz1kZmevV9g
Jan 26, 2012 | 1990 Honda Accord
My 19 inch technica lcd tv won't stay on
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter..
Aug 26, 2011 | Televison & Video
Televison & Video Logo
109 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
