Question about Philips 50PFP5332D 50 in. Plasma Television
Phillips 50PF9431D/37: Perfect Picture, inuadible audio
I have a Phillips 50" Plasma TV (model # 50PF9431D/37). Since two days ago, I have been having problem with the audio quality of this TV but the TV still produces perfect pictures on the SD channels. The audio is either totally inaudible or really really low even when you raised the volume to the highest level - 100.
And moreover, I noticed that neither of the two HDMI ports on the TV is working, hence I am unable get any pictures on the HD channels....it only gives me a green screen.
Can anyone help me with these problems?
Thanks
The audio or sound IC (integrated Circuit) on the TV panel maybe bad and need to be replaced.
Also, the speakers of the TV may have a weak connection from inside the panel.
But my best bet is the first solution i gave. If u are not a qualified electronics technician then take it to a service centre.
Joseph Asoh,
Abuja, Nigeria
Posted on Mar 12, 2009
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
PHILLIPS PLASMA TV MODEL #42PF9431D/37 Heard
Hi, Usually any "Pops" are an Electrolytic Capacitor "blowing up" quite literally, or "Gassing" as it is called. This happens due to some sort of power problem. Capacitors hate AC Voltage and Current, and Heat and Over Voltage. All of which, I have no doubt it was exposed to before it went "Pop" This is only a symptom of a far greater problem, to come, no doubt, soon, the rest of the set will fail too. Please DO NOT USE. this set any more, you risk fire or explosion or both. If you MUST use it at least unplug at bed time. Theses days home repair except for the most rudimentary problem is not feasible, setting aside the safety aspect. In my professional opinion, I would recommend, that you get a "Quote" for repair from a Philips Authorised Service Agent This is very important, that you contact a Philips head office and ask for a referral. This way at least you can make a decision to repair or replace.
Apr 01, 2010 | Philips 42PF9431D/37 TV
I have a phillips 50 inch plasma- model 50PFP5332D/37- when its plugged in it makes a clicking noise and the light is on indicating it is on, but picture never comes on- help
you have a problem on one of the boards in this unit you would have to start isolating the source to pit it down
its probably best you get some help form a servicer in your area this is a philips inside and made by samsung
Oct 23, 2009 | Philips 50PFP5332D 50 in. Plasma...
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
System will not power up
Remove the back from the set and look at the power board in the center of the TV. It will probably have one of more capacitors with the tops bulging out. Replace them with the same value part. Available from radio shack and almost any electronic suppliers.
May 16, 2009 | Philips 50PF9731D/37 50 in. Plasma...
D3V3 Trouble code on Phillips plasma
I had the same problem with the same Model TV. after doing some research i found that i had 2 bad 3300uf capacitors. I made a video of the repair and posted it to youtube. the TV works great now! Check out my video! i hope this helps.
Dec 11, 2008 | Philips 50PF9731D/37 50 in. Plasma...
Philips 50PFP5332D 50 in. Plasma Television Logo
356 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
