Question about Nikon D80 Digital Camera
Dark photos I am a new Nikon user and have the D80. This is way more camera than I will ever need. I can not take pictures without them being dark not even in the auto mode. This is inside or outside I have two lenses and have switched them and it's still dark. I was able to change the exposer to get them lighter but would think you could take pictures in auto that would be fine.
  • statementboa Mar 14, 2009
    I am just a little confused! If the camera is in green auto you are not able to change the EV and I'm not sure how to check the internal meter. My lens does not have M/A or M.
  • statementboa Mar 16, 2009
    I have read the manual and tried searching for internal meter through the index and can not find anything on internal metering. I will give it another shot. Thanks you have been alot of help.
    Scholar:
  • Nikon Expert
  • 115 Answers
  • Be sure camera is set to the Green auto, not the A (A= aperture priority)
  • Be sure your white balance is on auto.
  • Be sure your EV is set to 0
  • Be sure your lens is on M/A, not M
  • Check the internal meter. See if it is showing a middle of the graph reading when the camera is on auto. If it is and you still get dark pix, might be time for Nikon repair.
Posted on Mar 14, 2009
  • Jeff Marcus Mar 14, 2009
    Your meter is the most important thing to understand to get a decent exposure. A picture is all about light. The meter measures that light. I suggest reading the manual on at least this section. After that, see if the meter is registering a proper exposure. Then, if your photos are still dark, it's back to the dealer or Nikon.
  • Jeff Marcus Mar 16, 2009
    Looking through your view finder you should see a light/exposure meter. Try taking it off automatic and see if that causes the meter to appear. Too far to the left of center is dark and too far from the right is too light. The adjustments are done through your aperture setting, shutter speed and ISO. Depending on what type of photo you want, I would use either aperture or shutter speed priority. Keep your ISO as low as possible and crank that up if you don't have enough available light for a decent exposure (light/exposure meter). These three items make up the exposure triangle. Changing one causes the cam,era (or you in manual mode) to adjust for the other. For most photography of non-sports related or indoor shots, aperture priority works really well. You set the aperture for the depth of field desired and the camera adjusts the shutter speed for you.
    I can also be reached at marcusphotography@gmail.com
    Jeff
Why do my pictures look dark when i take them to my local printers or send them to printers on line
it is different, photo is RGB light, but printing use CMYK ink, never match the photo and the printing result
Sep 01, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 fell from a foot n half above the ground level well packed in a good quality carry case few days back.uv filter attached to 18-135 Nikor lens cracked & lens cap was jammed. After carefully...
Hi, allow me to suggest using another lens to see if you still see the dark patches in the top corners. If not it is the lens, if so it is the camera. Either way it sounds as though something is maladjusted. Call Nikon digital 1-800-645-6689.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
The picture come out to dark
This sounds like a very basic question. If you are a basic user, I suggest to move the camera dial to Auto to make sure you have properly exposed pics all the time.
Other things you can do to manually brighten up your photo:
- use lower shutter speed
- use larger aperture (smaller f number)
- use higher ISO
- use artificial light (flash, reflector, etc..)
Oct 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Dark Viewfinder and Slow Shutter Speed
At first it sounds like a faulty aperture blade that is stuck after your first press. However you mentioned that this happened in other lenses as well. Seems to me that there is a problem with your camera (e.g. mirror lockup problem or something else). Pls have it looked at by Nikon
Aug 13, 2009 | Nikon D80 Digital Camera
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
I have a Nikon D80 SLR camera, and have purchased an Opteka 650 x 1300 mm zoom lens (fit on). I have changed the setting on the camera to manual, and it will now take photographs, however the images are...
You can't meter through that lens. If the images are too dark, either slow down the shutter speed or open the aperture. Keep going until the picture looks okay on the monitor. If you know how to use the histogram, that's even better. If you go too far and get images too light, reverse the process (faster shutter speed or smaller aperture).
If you have another light meter, you can use that to get a ballpark exposure to start with. Alternatively, take a reading with your other lens at the longest zoom.
Jun 15, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
D80 Nikon - dark in viewfinder
What you see through the viewfinder is not exactly what you get in your picture. It is possible that your settings are just off in the camera. To make sure that this is the problem, set your settings to Auto and try again.
The red light before the picture is taken is a setting you can turn on to indicate that you have focused correctly. You can turn this off in the menu if this bothers you.
Lastly, I do not think your camera is broken. You just need to read your manual to make sure your settings are correct when you take a picture. Hope this helps.
NOTE: Please rate our help to keep this free service online
May 08, 2009 | Nikon D80 Digital Camera with 18-200mm...
Nikon coolpix 4800 - built-in flash may need to be replaced
I have the same camera and have had the lens cover get stuck and it will leave the dark shadow in the pictures like you describe. It doesn't always happen, but when it does I just gently push the lens cover all the way open with my finger.
Mar 05, 2009 | Nikon Coolpix 4800 Digital Camera
I was at a basketball game last night and taking pictures with the d80 and the 55-200 lens. All of the pictures I took in auto focus were blurry. I changed it to the S mode with shutter speed at 4000 and...
Hi and welcome to FixYa.
I could go into a long disertation about your camera settings and what you should use, but I should let Ken explain it. I read this a couple of months ago (because I love photography too)! He has some good ideas, tips, tricks and really has the D80 dialed in. You can read it here.
http://www.kenrockwell.com/nikon/d80/users-guide/d80-users-guide.pdf
Good luck and have fun with your camera.
Rob
Feb 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D-80.
See the Manual: showing the picture actually shot is an option in the camera setting.
May 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera Logo
115 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
