Question about Ovens
Where do I buy a robertshaw infinite switch for a oven Type B 250Vac 8.9 to 11A;318220001;QE214434 & I live in Mississauga Canada
  • The make is Frigidaire and the model number is CFEF357C. The infinite switch is for the larger coil which is located in the front among a set of 4 coils.
3 Suggested Answers
  • 12 Answers
SOURCE: Hi.Thank for help. I have found the problem. One
you may have 1 or 2 sensors, look inside oven, the sensor will be 4 inch or more, It will look thinner than a pencil.
Posted on Dec 04, 2010
noranda21
  • 1547 Answers
SOURCE: I hav e 2 coils
whats the name on the oven and model number most of the time you can look in a phone book im not sure if they have a home depo or a lowes call around with name and model number hope this helps
Posted on Dec 06, 2010
Oven won't heat up
Check the oven fuse, there should be one on the top of the over, under a cover. If its OK, remove screws that hold the element in place, pull it out far enough so you can get your test meter clips to attach to the 2 wire contacts. Attach the meter set to at least 250Vac. Make sure its not touching any metal parts of the oven during the test, and that your leads are away from the element. Turn the oven on to 350. If you have 250Vac at the meter your element is bad, if no voltage your switch is bad or broken, burned or loose wire going to the element or on/at the switch..
Feb 15, 2015 | Ovens
Grill burning everything even on lowest heat and lowest shelf, is it element or thermostat, and does grill have separate therostat to main oven.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
god is gooddddd
Jul 11, 2014 | Zanussi ZHQ575 Electric Double Oven
Small back elements only work on high settings
The infinite switch
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 11, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Direct spark ignition wont fire on bake or broil
Surface burners
The infinite switch
The infinite switch
Apr 05, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Only two hobs heat up
Surface burners
The infinite switch
: I offer free advice bcuz God is so good!
Mar 19, 2014 | Belling XOU174 Electric Single Oven
Only one grill element works
Surface burners
The infinite switch
Jan 18, 2014 | Belling XOU592 / XOU593 Electric Double...
MODEL WFG231LVQ0 OVEN AND BROILER WONT LITE BURNERS WORK
are you sure about that being the reason. I would check the infinite switch's
Surface burners
The infinite switch
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Sep 06, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Hob burners will not stay lit when knob is released
Surface burners
The infinite switch
Mar 10, 2012 | Belling Ovens
I hav e 2 coils not working. How and where can i buy the replacement? I am here in Mississauga, ON, Canada, L5L 1H2.
Dec 06, 2010 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
