Question about Alphasonik PMA600HC Car Audio Amplifier
Clipping amp
Driving home the other day and I smelt something burning then my bass went. The amp cuts on but now when I turn the volume up the amp cuts out and proceeds to clip. The power ligh start to blink.
  • kevin james
    kevin james Aug 05, 2007
    you were right one of my speakers wired had melted and started touching. Now when I fixed the touching the speaker still works. I hooked them back to the amp not bridged and it worked. Now I gotta see if the bridge still works or if that was blown. If it is blown what do I do?
Werw
Posted on May 24, 2008
    Problem Solver:
  • 11 Answers
Hi first disconnect all spks, then turn on the amp. if amp power lite stays on bright then proceed to connect one speaker or sub to the amp. if the amp lite dims during any spk connections then it may be that the spk is faulty or there is a DC voltage (dc offset) emitting thru that particular channel. also check all spk impedance before reconnecting them to the amp. cheers.
Posted on Aug 05, 2007
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
My DB Drive pd 1200.1 amp shuts off when the volume is raised. What is happening and what should I do?
The vibration from the bass is cutting off the amp. it is a loose wire causing this issue. you can also get a stabilizer that will stop the vibrations from causing this issue.
Feb 27, 2013 | DB Drive Platinum PD1200 Car Audio...
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Cuts out when volume increased
it went to protection mode check your cables first and then check your speakers-and confirm no cable touch each other(try with another speakers had same rating)(watt)--means how much power can get.
Jul 28, 2008 | NAD C320 2-Channel Amplifier
Alpine mrp-m650 amp cutting out
Some AMPs have a thermal cutout, that switches the amp off if it gets too HOT.
But this sounds like your amp or sub is screwed, either there is to much resistance in your sub, eg: Burnt voice coil, carbon builds up on the coil stopping the sub from moving freely. Push on the cone of the sub & listen for a scrapeing sound.
or test this by continuity testing the sub terminals & pushing the cone if the BUZZER on the MultiMeter cuts in & out as you push & release then your sub is screwed. ( a certain amount of repeatative pushing it may free up the voice coil.)
or your Amp may have blown a internal fault that will have to be sent of for repair.
Or you have a incorrectly rated fuse for your system,
or the battery cant kope with the power surges???
THIS DOES NOT APPLY TO YOU AS YOU HAVE A POWER-CAP!!!
Dec 19, 2007 | Alpine MRP-M650 Car Audio Amplifier
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Alphasonik PMA600HC Car Audio Amplifier Logo
431 people viewed this question
Top Alphasonik Car Audio & Video Experts
Mike Duncan
Mike Duncan
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
