Question about Panasonic KX-T7633 Corded Phone
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
  • Panasonic Master
  • 2,460 Answers
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Posted on Mar 16, 2009
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
We have a KX-TD816 system and I have a KX-T7431 phone. We have no operator so whoever picks up transfers. No one can transfer to me anymore. One other thing all the phones the FWD/DND button blink slowly....
So what happens when they press TRANSFER and dial your extension? What happens when you call someone with a display phone and your extension comes up on the display?
The FWD/DND button shows that you have a FWD or DND condition set on your phone. Try pressing it one or 2 times and see if the display says FWD to xxxx. Now, if it is cleared, from the intercom dial 7104 (busy) or 7105 (no answer) 165 # That sets the CF on your phone.
If the others have lost your DSS button on their busy lamp fields, and truly nobody can "transfer" calls to you, you can reprogram those with PROGRAM 99 (don't pick up the handset) press the button assigned to your extension and dialing 1 + your extension and STORE.
Carl
Mar 23, 2011 | Panasonic KX-T7431 Corded Phone
Why can't I turn off the FWD/DND flashing light?
It will flash for 2 reasons. The phone is in Do Not Disturb, The phone is forwarded and the lazy installer didn't change the button indication to solid.
What happens when you press the FWD/DND button on an idle phone? In most systems, it's supposed to toggle between FWD DND and OFF after you press it more than once. If that doesn't work, try pressing FWD STORE 0 STORE. That should turn off FWD/DND and unset it.
However, here's the problem. Your phone may have CF-condition set to send busy and unanswered calls to voice mail. We do that so the individual extension can set his own transfer to VM time. Those commands start with *710x and the VM extension which is 500 by default. For example dialing *7104 500 on the intercom will set CF-NA to the voicemail port on a TDA/TDE system equipped with a Panasonic Voice mail system. When that happens, the FWD/DND light goes either red or blinks red and the forward condition is set.
You can review the operations in the OM for your system under Call Forward and Do Not Disturb.
Carl
Mar 04, 2011 | Panasonic KXDT343 Phone
How can i active or desactive the FWD/DND in the model. KXT7730?
it really depends on your phone system
but the possibilities are:
1) "INTERCOM"
2) *710
3a) 0 to deavtivate
3b) 5 to set to busy/no answer
4) put the number you want to fwd to then "#" *confirmation tone*
or
1) "INTERCOM"
2) 710
3a) 0 to deavtivate
4) put the extension number you want to fwd to *confirmation tone* (extension number only)
Jan 03, 2011 | Panasonic KX-T7730 Corded Phone
I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
HOW TO LEAVE A VOICE MESSAGE ON A PANOSONIC kX-t7636
Your VM has an extension, usually 165 or 500. You forward your phone to Voice Mail by dialing *710x 500 # where x is 2 for all calls, 3 for busy, 4 for no answer or 5 for NA/Busy. I use 4.
The FWD/DND light will blink and the display will say Call FWD (condition) 500.
Now, all calls, both from the inside and outside will forward to the voice mail system.
Carl
Apr 15, 2010 | Panasonic KX-T7636BK Digital Telephone...
FWD/DND
The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
Here's a quick cut and paste from the OM for 76xx phones.
Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
Carl
Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
Calls don't go to voice mail if on another call
You need to go into programming and set the FWD NO ANSWER, to go to the voicemail extension.
Also check FWD ON BUSY, that should go there as well.
Jul 09, 2009 | Lands Phones
Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Oct 01, 2008 | Panasonic KX-T7633 Corded Phone
Fwd/dnd button will not flash
FWD/DND is programmed in the system, not the phone. When you figure out what system you have, post again.
Carl
Jun 06, 2008 | Panasonic KX-T7130 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
1,224 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
