Question about D-Link Xtreme N DIR-655 Wireless Router
Completed setting up my new DR-655, however, not able to connect to internet, wired or wireless.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- Kindly try to power cycle your modem and the router for about 1 minute.
- Turn On first the modem and make sure you a stable on it before you turn On the router.
Posted on Mar 14, 2009
I have a D-link DIR-655 wireless router . I have two computers wired to the router and I run a wireless laptop. A couple time a day I lose connection and get a message thay says "local connection...
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Aug 04, 2017 | D-Link Xtreme N DIR-655 Wireless Router
How do i access the NAT settings for my D-Link DIR-655 Router. i believe the strict setting is affecting the WiFi i need to connect to the internet through my computer.
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Xbox/PS3/Wii in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Oct 24, 2010 | D-Link DIR-655 Wireless Router
Connect dlink 655 router. Wireless works well on laptop pc and on 2nd desktop wireless, but does not work on base set. Why?
There are number of reasons, but lets try something 1st
Assuming your computer is fit, try a WIRED connection. If that works, we know your base set is configured properly to receive the internet.
If it does not work wired, then we need to find out why (another topic, specify wired)
Things to look at for wireless:
The settings on your PC for the wireless adapter:
Go to settings (network) rightclick on properties and bring up the network device properties.
Go to the advanced tab and check the configuration of:
MTU (Maximum Transfer Units) is set to auto or to the same as your router
Channel, make sure your PC is on the same channel as your wireless is broadcasting from.
Workgroup, insure that your workgroup is the same for all computers in your network (for file sharing)
Make sure you have an antenna to receive wireless on your desktop.
The are the common things.
good luck and don't forget to vote!!!
Sep 27, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Suddenly unable to connect wirelessly to dir-655 but still able to be connected via wire connection
Login to the router interface and check the wireless settings,change the Wireless channel to 9 for the 2.4 Ghz and also look for the firmware upgrade.
Mar 15, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a DIR 655 D Link router and I can't save changes.
Lots of possibilities, especially if the wireless device and your PC are older - the DIR 655 doesn't support wireless protocols 802.11 a and b, for example, only the newer g and n.
Start with getting the router software up to date (see )
using an Ethernet link to a PC, and then debug the wireless access. The DNS message could be caused by the Windows wireless adapter config having a manual IP address vs the router being set for DHCP (dynamic) or vice versa.
Sep 10, 2017 | D-Link DIR-655 Wireless Router
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
362 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
