Question about Harman Kardon DVD Player DVD-27
NO VIDEO: I had rented 3 DVDs. I was watching the first one and stopped it. I inserted the second DVD into the player and the video was completely gone. Please help me. Jessie
  • 1 more comment
  • JESSIE JACKSON Aug 08, 2007
    I WAS WRONG IN STATING THERE WAS NO VIDEO. THERE IS VIDEO, BUT THE SCREEN IS SPLIT INTO TWO VERTICAL SCREENS.
    BADJACK
    I AM NOT MECHANICALLY INCLINED. I REFUSE TO OPEN A NEW MACHINE TO TRY TO ATTEMPT REPAIRS.
    THANKS,
    BADJACK
  • JESSIE JACKSON Aug 09, 2007
    Thank you, Benimur at the Fix Ya Team. By, pressing the P/S (progressive scan button) on my remote control device, my system is working perfectly again.
    THANKS,
    BADJACK
    Brigadier General:
  • 6,966 Answers
Hi, Its possible that dirt (even just dust) is blocking the eye (optical). You may need to seek the services of a qualified service professional since the unit has to be opened and the optical lens cleaned. Should you venture into doing it yourself, with the power of & unplug, remove the cover lid exposing the inside mechanism and electronics. A sliding bar near a black disc (spindle) would be holding the eye. You need to check/clean the said eye and make sure that no foreign object is on top. Even a speck of dust or a small fiver or hair would cause it to fail reading your DVDs. It is also possible that the sliding bar is stuck at the far end or near the center. Gently shake it loose if it is so. If this does not work, I guess you're back to the first suggestion. Hope this works out for you and give you some ideas. Pls post again how things work out and/or if you need further information. Good luck and kind regards.
Posted on Aug 04, 2007
  • Louie  Role
    Louie Role Aug 09, 2007
    Hi again Badjack,
    Based on your new post/description, there is no mechanical problem with your DVD player. One can try is to to go to the setup function via your remote and set your progressive scan mode or sometimes called PScan mode (causes the split screen/display) back to default or off or back to interlace. In your remote it is the bottom right button.
    You may have to consult the your manual for a more comprehensive instruction, It is likewise available online athttp://www.harmankardon.com/product_supp...
    Hope this works out for you. Good luck and pls post again how things turn up. Cheers.
  • Louie  Role
    Glad that your unit is back to normal and to be of assistance.
How do I fix a grainy/ patchy jumping/skipping dvd.
Hello, Bloody_dark -
Often those who rent DVDs or borrow them from the local public library mishandle them and do not know how to handle them properly.
From your question, it seems the DVDs are either scratched or dirty (possibly with food residue.)
This website gives step-by-step instructions on how to clean the readable side of a DVD:
https://www.wikihow.com/Clean-a-DVD
If, after cleaning, the DVD still is grainy, patchy, skipping, etc., it is probably scratched.
What I do when I have a rented or public library DVD which is scratched, I return it with a "sticky note" attached to the DVD box stating it is scratched and that I properly cleaned residue from the readable side of the disc, so that the rental business or the library staff will know that the DVD is damaged and can choose to replace it.
There are ways to remove scratches from DVDs, but I do not recommend anyone try those steps if they do not own the DVDs themselves.
Note: I am a librarian by profession and have seen firsthand how people mishandle DVDs. I'm from the 45-rpm and 33-rpm vinyl record generation. We learned how to properly handle those vinyl records so as not to scratch them. Bottom line: We were taught to only handle the vinyl records (and subsequent CDs and DVDs) by their outer edges. For CDs and DVDs, they can be held between the thumb and forefinger, along the inside and outside edges.
Jan 10, 2018 | Polaroid Televison & Video
Tip
Watch DVD Videos on Nokia 5800, N97, Sony walkman (NWZ-S616F, NWZ-S618F) mp3...
Obviously phones don’t have DVD drives, so to watch DVD on a phone like Nokia 5800 you have to convert it into a video file on your PC then drag it into your phone. This article will show you how to Rip Movie DVDs and Convert videos like YouTube video, HD video(.MKV/.Mod/.M2ts/.tp) to Nokia 5800, N97, Sony walkman (NWZ-S616F, NWZ-S618F) mp3 player for watching.
The leading role of this article is Daniusoft video converter suite, it is already optimized for output setting for mobile phone, Sonywalk man in its profile. Very easy to use, like the follow illustration:
Oka, without further ado, let’s cut to the point to get things work
First of all, Download Daniusoft video converter suite, after installing it, you will get two software DVD Ripper and video Converter.
Next step, Run Daniusoft Best DVD ripper to rip movie DVDs and convert videos to Nokia 5800-friendly format. The nifty DVD Ripping software has all essential functions such output profiles, parameter settings and video edit. The detailed conversion process are show as below:
1. Insert your DVD disc into your DVD-Rom (Ensure that you have sufficient space on hard drive to store the DVD). Click ‘Load DVD’ button to add the DVD file. You can also click ‘Load File’ to add DVD/IFO from your hard disk.
2. Select profile “Convert to -> Mobile phone -> Mobile phone video (*.MP4)”.
P.S. If you wanna extract play back music from DVDs and convert to Nokia 5800, Sony walkman (NWZ-S616F, NWZ-S618F) , Just Select profile “Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)”.
3. Click “Settings” to tune codec parameters like Bit Rate, Video Size and Aspect Ratio.
4. Click “Edit” to edit the video in effect, length, size and watermark.
5. Click the protruding button on the right bottom of main interface to start the Movies DVD to Nokia 5800 conversion
Using Daniusoft Best video converter to Convert video to nokia 5800 is as easy as Daniusoft DVD Ripper
1. Run Daniusoft video converter and load your HD video files.
P.S. If you wanna extract play back music from videos and convert to Nokia 5800, Sony walkman (NWZ-S616F, NWZ-S618F) , Just Select profile “Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)”.
5. Click the protruding button on the right bottom of main interface to start the videos to Nokia 5800 conversion.
Now, you can connect Nokia 5800 to computer and copy these converted DVD videos to your Nokia 5800. To this analogizes, you could easily convert DVD videos to your N97, Sony walkman (NWZ-S616F, NWZ-S618F) mp3 player . Using the video converters well can cover the boring journey on a bus or a plain with myriad Christmas happiness and fun.
on Dec 28, 2009 | Cell Phones
What is the best program to use to put movies on my player?
As for me, i all through use Daniusoft video converter suite to convert various videos even Movie DVDs or HD videos to sony walkman-friendly format, and then put them to my Sony Walkman Video NWZ-S616F MP3 Player for watching ...
Jan 06, 2010 | Sony Walkman NWZ-S616F MP3 Player
RDR-VX530 will not play DVDs rented from Video store. Set of 3 DVDs, played first DVD will not play DVD 2 or 3. Displays loading message for couple of minutes then ejects DVD. Intermittent problem with any...
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 04, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Screen says loading and after a while, says disk error.Then eject
hi try first to insert a clean up CD, and test your DVD player with an original DVD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
Apr 12, 2009 | Televison & Video
I have a Cyberhome CH-DVD 300 and put it in progressive scan
turn on dvd player,leave disc tray close,press and hold in the stop button for five seconds,the dvd player will restore to factory settings and you will see the welcoming screen again,happy viewing watching your favourite dvds
Feb 28, 2009 | Cyberhome CH-DVD 300 DVD Player
Picture sticks, breaks up repeatedly
Change the location of the unit, this sounds like an overheating problem. It is too close to other units or is enclosed in a tight space. You may also try putting a small fan behind it to cool it down.
Sep 16, 2007 | Samsung DVD-V1000 DVD Player/VCR
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Harman Kardon DVD Player DVD-27 Logo
128 people viewed this question
Top Harman Kardon Televison & Video Experts
Demonic-2011
Demonic-2011
Brett Duxbury
Brett Duxbury
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
