Question about OKI ML321 Matrix Printer
Constant Alarm Light on Oki ML 321 elite
We have a constant red alarm light when we switch on the oki printer, it seems that the ribbon trys to run then makes a funny clicking noise and goes back to its original position on the far left, wherever you leave the ribbon to begin with.
  • richard_ward Mar 12, 2009
    Also, there is nothing blocking the carraige to stop the ribbon running.
  • NEV2DEP May 11, 2010
    Is the alarm solid or flashing?
    are you using genuine Okidata ribbons?
    also try powering the printer on without the ribbon, does it still show the same alarm condition?
SOURCE: Oki 320 turbo alarm light
Check/clean the carriage sensor. This part is under the head/ribbon holder assembly. You should also check the tensioner to the black guide/railings when the carriage assembly runs. This is the one with the gear.
Efi
Posted on Nov 12, 2007
SOURCE: Problem with OKI ML 395
Problem is with your carriage motor,it needs to be replaced.
Regards
Dezzi
Posted on Dec 08, 2007
SOURCE: OKI Pacemark 3410 Matrix Printer Error Writing to LPT1
A blinking alarm usually means an hardware error of some type, such as an obstruction on the printhead, or a bad motor or such.
When you have a blinking alarm light the other lights that are on will give you an error code that will tell you what the alarm means. You will need to look it up at Okidata.
Posted on Dec 10, 2007
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
  • 40 Answers
SOURCE: printer not printing
Try taking the ribbon out and power the unit on, does the alarm light go off ?
If so the ribbon could be jammed.
Posted on Nov 23, 2008
OKI MICRONLINE 320 TURBO
Remove the ribbon it may be jammed and if this does not work your printer has a problem with either main logic board or carriage motor.
Dezzi
Aug 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 280 Elite Matrix... Problem
Be sure when you install new paper that the paper out switch, usually in the paperpath somewhere, is being contacted by the new paper. Usually located on the left side of the paper platten.
Jun 04, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Alarm light on permanently
make sure all compartments are closed
make feed doesnt have a stuck page in it
sometimes if the compartments arent closed right or by some chance the ink cartridge was bumped this will sound the alarm
May 22, 2008 | OKI MICROLINE ML-395 Matrix Printer
Alarm red light flashing when I switch on the printer
HI ,
Is the front cover on ? becuase this printer cannot work with the cover off ?If the cover is on remove the ribbon and power the printer on if it works the ribbon could be the problem.
Dezzi
May 13, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer not printing
Hi mzitho, please download the Pdf manual. Click on this link for the main page for the okidata ML320Turbo.
http://my.okidata.com/PP-ML320Turbo.nsf
For the english manual click this link.
http://my.okidata.com/mandown.nsf/1fe7d58578ca7f99852569af0042834b/e08d475cb4b6bf4a852569590039ffc6/$FILE/ae320tug_07.pdf
You can choose to cerat a folder on you're desktop & save the pdf file within that folder or allow the pdf file to load & save it later. Once the pdf file has opened. Click the plus sign next to Contents. Than open Troubleshooting, open List of problems. Follow the instructions for problem 7 & 8. If you feel it's a memory issue than type memory in the find window within the pdf file & continue to search untill you find what you think you need.
Good Luck!
Mike
May 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
check the mesage in your operating mannual
Sep 13, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI ML321 Matrix Printer Logo
228 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
