Question about Intermatic & Indoor/Outdoor Rain Tight Timer
T40004rti timing control - Intermatic & Indoor/Outdoor Rain Tight Timer
How do I fix trouble code p1354 on a 2000 Toyota avalon?
P1354 Toyota Description
Variable Valve Timing (VVT) system controls the intake valve timing to proper timing in response to driving condition. The Engine Control Module (ECM) controls Oil Control Valve (OCV) to make the intake valve timing properly, and, oil pressure controlled with OCV is supplied to the VVT controller, and then, VVT controller changes relative position between the camshaft and the crankshaft.
Read more: http://engine-codes.com/p1354_toyota.html#ixzz3LEjKp1Z2
Dec 07, 2014 | Toyota Cars & Trucks
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Feb 07, 2014 | Toshiba Computers & Internet
Quest code p1136
P1136 NISSAN - Intake Valve Timing Control Solenoid Valve Circuit Bank 2
Possible causes- Intake valve timing control solenoid valve bank 2 circuit is open or shorted.
- Intake valve timing control solenoid valve bank 2 circuit connectors
- Intake valve timing control solenoid valve bank 2 Tech notes Since the Intake valve timing control solenoid valve uses oil flow to control timing, dirty oil can cause the valve to stuck open or close. Before replacing the valve, change engine oil and filter and reset engine code.
Aug 29, 2012 | 2005 Nissan Quest
Nissan code p1136 p1124
P1124 NISSAN - Throttle Control Motor Relay Circuit Short
Possible causes- Throttle Control Motor relay harness is open or shorted
- Throttle Control Motor relay circuit poor electrical connection
- Fualty Throttle Control Motor relay
I have a 2003 a4/b6 1.8 turbo and the engine light is on. The DTC codes says random misfire, misfire on cylinder #2 and #3 also, Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean : P1111. Any...
If you can supply me with all the codes your vehicle is showing, I can assist you. As far as the P1111 DTC goes I have listed the info below with some possible solutions.
P1111- Intake Valve Timing Control Solenoid Valve Circuit Bank 1
Intake valve timing control solenoid valve is activated by ON/OFF pulse duty (ratio) signals from the ECM. The intake valve timing control solenoid valve changes the oil amount and direction of flow through intake valve timing control unit or stops oil flow. The longer pulse width advances valve angle. The shorter pulse width retards valve angle. When ON and OFF pulse widths become equal, the solenoid valve stops oil pressure flow to fix the intake valve angle at the control position. The code is triggered when an improper voltage is sent to the ECM through intake valve timing control solenoid valve. Since the Intake valve timing control solenoid valve uses oil flow to control timing, dirty oil can cause the valve to stuck open or close. Before replacing the valve, change engine oil and filter and reset engine code.
Possible Causes:
- Intake valve timing control solenoid valve bank 1 circuit is open or shorted.
- Intake valve timing control solenoid valve bank 1 circuit connectors
- Dirty Oil
Possible Solutions:
- Change Oil
- Replace Intake valve timing control solenoid valve
Jan 20, 2011 | 2003 Audi A4 Cabriolet
P 2138 code with service engine soon light on?
Accelerator Pedal Position Error.
P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
Clear the code - if it recurs, change the sensor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 15, 2010 | 2006 Nissan Altima
Lost my manual and cant figure out how to set the time. Any help out there. Thank you
From the user's manual
Setting the Clock
1 Turn the Mode control until the clock icon is highlighted
with brackets .
2 Press the Mode control. The clock icon and time display will
flash.
3 Turn the Mode control to adjust the time.
4 Press the Mode control again to set the time. The display
reverts to its previous mode and the new time is set.
Note: The clock can display time in either 12 hour or 24 hour
format. To change the time display turn the mode control to
highlight the clock icon with brackets . Press and hold the mode
control for 5 seconds. The display will show “12H” or “24H”. Turn the
mode control to select the time format you want, then press the
control.
Mar 08, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Instruction Manual
Normal 0 Conairphone Digital Answering Machine -- Model TAD2018CG
http://www.conairphone.com/Pages/quick_reference.html (try TAD920)
Answering System Operation
A. Recording your personal outgoing announcement
1. Press and hold down the ANNOUNCE control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your announcement and reset to
answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
B. Setting the Voice Time/Day Stamp
1. Press and hold the TIME/REPEAT control for 2 seconds until you hear "Monday 12:00 AM".
Release the control. Press and hold the On/Off Control until you hear the correct day.
2. Press and release the TIME SET/REPEAT Control. Press and hold the ON/OFF Control until
you hear the correct hour.
3. Press and release the TIME SET/REPEAT Control. Press and hold the ON/OFF control until
you hear the correct minute.
4. Press release TIME SET/REPEAT Control. Press and hold ON/OFF Control until you hear PM.
Press and hold PLAY Control to return to AM.
5. Press and release the TIME SET/REPEAT Control to complete procedure. Unit will prompt
the day and time.
Apr 15, 2008 | Conair TAD2018CG Digital Answering Machine
Pioneer DEH-P3000IB operations manual
How to set the clock on the DEHP3000IB?
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF] (power/source button)
Pres & Hold [Muti-Control] (big button that controls volume) until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segment.
Mar 16, 2008 | Car Audio & Video
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
