Electric cord becomes extreamly hot when using a very short time.
Electric cord becomes extreamely hot . We have not used this heater very much. Only in our Motor Home when traveling in cold weather in overnight camping. We have an older one that works just fine. You rebuilt it also, but this one seems to get too hot ( cord). And the wife won't let me use it for fear of fire.
    New Friend:
  • 92 Answers
The wife is right you have a problem with heater or electric supply to heater dont use it
Posted on Mar 16, 2009
Cant adjust temperature
check to maker sure lights are going off when door is closed , if not it will get extreamly hot ibn refrigerator and cause lights to go off and stay off til cool,
Nov 29, 2013 | GE CustomStyle PSC23NSTSS Stainless Steel...
I have a samsumg galaxy when charging gets extreamly hot why?
it maybe because of your battery or your charger,.it maybe had short circuit, you may bring your phone and charger to a cellphone technician to have it check..
Mar 08, 2011 | Samsung Cell Phones
My acer ferarri 1100 is overheating extreamly. Even cant touch the surface. This is happening only if I I change power profile to high preformance
You can get a USB cooling fan for laptop that will help with overheating.
Also to avoid laptop overheating, follow the information from this link.
May 19, 2010 | Acer Ferrari 1100 Notebook
My maytag gas dryer has always taken a very long time to dry clothes....usually 2 hours. I have had it for 8 years and it has been this way the whole time. is this normal?
i would check air flow out of vent normally with plugged vent extreame amount of moisture is present in dryer on high temperature of air moving through dryer is
max about 140 degrees normally with room temperature arpund 70 the drying time is normally 60minutes or less
contributing factors to long dry time
pinched vent hose final rinse cold water
below 50 degrees remove vent screen inside dryer clean with hot water shine flashlight into vent opening verify not plugged if have candy or probe type
temperature gauge verify temperature
at vent exit
Dec 12, 2009 | Maytag PYE2300AY Electric Dryer
I have a century wirefeed 225 amp welder that goes into a high current state if I shut the machine off for 10 minutes then it will work fine for a couple of welds. I did change the circuit board already.
sounds like a component is over-heating, this would possibley be located on a power resistor attached to a large heat sink, try the set again, when it goes into high speed, detach the plug from the wall socket, taking extream care, gently touch the power resistors for high temperators, these normally run hot so the faulty one will be abnormally hot, be extreamly aware of the large capacitors, they will be fully charged and will give you an awfull belt.
Oct 16, 2009 | Welding Tools
Engine knocks cold ok hot
if its at the top end its pistion slap
if its at the bottem end(of your engine) its a crank shaft bearing.
with out going into extream detail,
a ting sound at the top is a pistion slap.... replace all your pistions posibly over hual the engine.
a dubble knock that gose with rpm but sounds 2 knocks very every fireing of the pistion is a crank bearing..... replace your crank shaft bearings.... all of them b/c metal gose threw an engine extreamly fast and will destroy other beraings. this knock on start up will turn into a knock all the time, then a very louad knock that will end your engines life.
unfortunetly the answer is engine rebuild and fast.
May 30, 2009 | 2003 GMC Envoy
Washer runs an extreamly long time. I do use HE wash liquid. I put it on 25 min quich wash and check on it 30-40 min later and it has 125 min to go??????????
Does your washing machine go to rinse or spin? If it does not there is a problem with the in bulit in heater. Please check underneath. It is possilble that the heater is faulty or a wire has come lose.
Aug 27, 2008 | Washing Machines
Magnet area is very hot
vtdeanda, usually that is a sign that the condensor fan is not running. Could be jammed with something. It sits in the back by the compressor. Check this out first..Catriver..post back
Jan 30, 2007 | Whirlpool GS6SHAXLS Side by Side...
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
