Question about DPA Microphones 4088 Professional Microphone
How do I replace dpa 4088 cable - DPA Microphones 4088 Professional Microphone
I have a Apex model LD: 4088. The 3 HDMI connections on the back do not work.
If other connectors or built-in tuner work, replace main board.
Sep 13, 2012 | Apex Digital LD4088 LCD TV
Are car adapters available for this model? Thank you
Yes, one should have been supplied with it if purchased new. If second hand then you can get a replacement from Amazon by the following link.
http://www.amazon.com/exec/obidos/ASIN/B001T8DL9E/dogtratipan0b-20/
Please leave feedback.
Cheers
Andy
May 26, 2011 | Polaroid DPA-07032S 7 in. Portable DVD...
HP Laserjet p3005x printer - Just received this printer from used stock. Every time we try to print in duplex, the paper jams under the toner cartridge after printing the first page and then being sucked...
Hello, This problem is commonly caused by what is known as the (DPA) duplex pendulem assembly. The function of th DPA is to switch the direction of the paper in order to print the duplex side. The DPA sometimes will bind and not work properly which results in the paper jam you have described. See Photo Below.
Pendulum assembly RM1-3748
In order to change this part, the printer needs to be dis-assembled. AN HP Certified Technician would be best to do this repair.
Find a Rpair Delaler near you USA http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Dec 17, 2010 | HP LaserJet P3005x Printer
Acer Aspire 7736z - 4088 I can no longer get the
It may be wiring problems in the articulation area of the camera. This was my problem and others had same problem. Try moving the camera to a different position a little at a time and then try connecting again. I tried downloading drivers, etc. not the problems with mine.
Jul 12, 2010 | Computers & Internet
Our direct tv remote won't work with this tv.. Apex & Direct have given us 7 codes, none work.
For the Apex 4088, choose Astar brand. Enter code: 11531.
If this doesn't work, 11548 or 11738
Good Luck!
Dec 21, 2009 | Apex Digital LD4088 LCD TV
Battery for DPA-08055s?
Spoke to Polaroid customer service after opening the box only to find out that an external rechargeable battery was NEVER made for this model! I advised them that the main unit has a hook-up for the battery...no smart answer to that one!
You can buy the bag at any Walmart.
Feb 20, 2009 | Polaroid DPA08055S Portable DVD Player
DPA-4088-F WIRELESS MIC REPAIR
Yes they are very expensive and very much worth getting repaired.
Call DPA and find out who/where the closest service center is for your area.
DPA Microphones, Inc., 2432 North Main Street, Suite 200,
Longmont CO 80501, USA
Telephone 303-485-1025
Jan 23, 2009 | DPA Microphones Audio Players & Recorders
DPA Microphones 4088 Professional Microphone Logo
41 people viewed this question
Top DPA Microphones Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DPA Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
