Question about Craftsman Garden
How to disconnect kill switches on a craftsman mower
2 Suggested Answers
  • 15 Answers
SOURCE: I replaced ignition coil on a Tecumseh Toro 20018
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Posted on Aug 12, 2010
Where are kill switches on my Craftsman 46" Hydrostatic lawn tractor?
how old is the mower? Usually one in the seat & under the engine cover where you depress the clutch/brake pedal. Good place to start. Hope it helps.
Aug 14, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How can I check kill switches/relays on a craftsman 17.5 Kohler riding mower
get and ohm meter and see if you got voltage coming in on the b pin and when you turn the key on see if you hae the voltage coming from the pin that is marked with a s,
if you disconnect the switch you'll see on the pin's letter's
there should be a B,L,S,G,etc.
Oct 06, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor turns over but won't start
i would check the switch on the brake/clutch it has 2 switches built into one jump it with a paper clip to test it
Jul 31, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Test seat switch
Disconnect it from the seat. Keep the plunger down with your fingers as if you're sitting on it with the seat, and start the machine. Let the plunger go and it the machine is running while in gear, the switch is bad. Also, you can use a multimeter to check continuity with the plunger up and down. That will tell you if it's working or not.
Jul 31, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman kill switches
I think there is one by the back axle on the right side. This one would be for the deck.
May 16, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
I have a Craftsman mower, model 917.273810, and when you engage the blades, the brake pads that are used to stop the blades from turning when you disengage the blades...won't release and it trys to...
Sounds like you have a broken spring #148 on diagram, part #169022 that holds the idler arm back. Go to www.searspartsdirect.com and enter the model # of your mower and click on the mower deck to print drawing out, take your deck off the mower and see if all the springs are ok. If the pads are closed on the pulleys and the pads release when you turn the idler arm, the deck is ok. The problem will be a bad or disconnected safety switch that cuts the motor off if you try to ingage the mower. If the switch is disconnected under the seat it will kill the engine when the mower is engaged. I had this problem on my mower, just plug the wiring into this switch or replace it if it is bad.
Aug 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No spark
Eigther the kill switch failed or ignition module. Disconnect wire to kill switch if you get spark then switch is bad. Still no spark with kill wire disconnected ignition module quit.
Sep 29, 2010 | Mtd Garden
Craftsman ys 4500 throttle kill switch?
if you push it that far you are choking the motor
back the throttle back down to slow and try to start the mower if it starts go back to fast but not all the way to choke
Apr 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
46 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
