Question about Motorola Mobility i560 Cellular Phone
Wont turn on
When i press the power button the phone says self check fail 00800 hit 4-5-6 to re-program the code plug
  • rosenburg Nov 20, 2007
    My phone won't switch on. Message on screen, "Signature bad Ready to program Connect USB or RS232 data cable"
    Any idea what to do?
  • Anonymous Dec 25, 2008
    Yeap same thing mine reads self-check fail 00800 hit 456 to reprogram
I just read something on this problem.. something to do with the phone being stuck in program mode and you probably have to take it to the store to have it fixed.
Posted on Oct 29, 2007
6ya staff
SOURCE:
Cant progam not understanding the instructions
The best way to program with this remote is to follow these instructions.
1. Turn the device you wish to program on by hand 2. Press and hold the key for the device you are programming. (If it's a TV hold the TV button etc.) 3. While holding the button down, press and hold the power button down until the light turns off, and then back on. Once the light is back on release both keys. 4. Now, while pointing the remote at the device, hit the power button until the device turns off. Once the device turns off, you have found the right code. 5. Hit the stop button on the remote in order to save the code, and program the remote to that device.
This should work for most universal remotes these days. It might take you a long time to find the right code as well, the code list is very long so you just have to keep chugging through them. I've reprogrammed this type of remote many times and have hit the power button for over 5-10 minutes before the device turns off. Best of luck to you.
May 04, 2011 | RCA RCR350 Remote Control
Codes for ge universal tv remote and how do i program it?
You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Oct 05, 2010 | GE Televison & Video
I would like to help me program my remote control my TV, I hope is a trademark relistic solve my problem thanks
Manual code entry
Auto configuration
Thanx
Aug 07, 2010 | GE JASRM24912 Remote Control
I don't know the code or how to program it to my magnavox tv or zenith dvd/VCR player
Manual code entry
Auto configuration
Thanx
Aug 05, 2010 | GE RM24912 Universal Remote Control
To program my TV JVC
Manual code entry
Auto configuration
Codes for JVC TV are
3 digit codes:
013, 012, 026, 054, 055, 060, 065, 067, 069, 089, 141, 197, 247, 901
4 digit codes:
0060 0026 0197 0069 0160 0247 0923 0012 0065 0067 0141
Thanx
Aug 04, 2010 | GE JASRM24912 Remote Control
Need code for slyvania tv & instructuins on how to do it
GE
Manual code entry
Auto configuration
Thanx
Aug 01, 2010 | GE JASRM24912 Remote Control
How do I program my ge universal remote RC24911-C? Do you know the codes?
Hi
Manual code entry
Auto configuration
You can get your codes for your device from below website
Thanx
Jul 31, 2010 | General Electric Universal Remote Control
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
I have a living solution remote control i lost the codes and i nneed to progam it to a sanyo tv
Try these steps to program your TV:
1. Turn off your device
2. Hold the button of what you want to program (TV,VCR,DVD) until the red LED light lights up
3. Press the power button
4. Keep pressing Channel up/down until the device turns on
5. Press “OK”
6. Press power and volume/channel buttons to check it
If you go too far and hit channel up/down again after it turns on, you missed the right code, so hit the opposite direction of what you were doing until it turns on again, then, hit “OK” to program the right code.
Mar 31, 2008 | Televison & Video
Motorola Mobility i560 Cellular Phone Logo
535 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
