Question about Mitsubishi Heating & Cooling
Mitsubishi reverse cycle air con.SRK 208 which is heating ikon on remote
Model SRL 208
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
crouchdash
  • 83 Answers
SOURCE: I HAVE MISLAID REMOTE CONTROL INSTRUCTIONS TO CHANGE FACILITY REQUIRED IE COOL, OR HEAT
You can download the owners manual; here is the link for it.
http://www.generalmanual.com/Air-Conditioners/LG-LA121CNP-Art-Cool-Air-Conditioner.htm
when you get to the page scroll down and you will see Download Now and under that "Owners Manual" just click on it.
I hope it helps.
Posted on May 27, 2009
  • 45 Answers
SOURCE: electra remote wont work with electra air con.
hi.you should have a sticker under the indoor unit head unit or on the side.
Posted on Jun 10, 2009
relaga58
  • 158 Answers
SOURCE: What do the mode icons on remote control for
change from what operation you want the a/c to do like fan only or cool only or heat only(if it has heating) or auto if you want auto change between heat and cool
Posted on Aug 01, 2009
shastalaker7
  • 1515 Answers
SOURCE: My reverse cycle air con (Mitsubishi MSH 12RV) is
I would check the reversing valve. This is what switches the flow of refrigerant for Heating and cooling.There could be several other reasons that could cause it not to heat.
Good Luck, Sincerely, shastalaker7
ps Heat pumps are very temper mental, like I said there could be many things that could cause this problem, and I couldn't walk you through them all. If you have a split system, two piece unit, go to the out side unit and have some run the a/c in cool. Then after a few min. have them switch it to heat and you can hear the reversing valve switch to heat, as it will make a swishing sound.If it doesnt, the valve may be bad, no power to the coil on it, or even the coil could be burned out.
Posted on Oct 30, 2009
I have a panasonic inverter air con. Model CU-E18LKR. it's not cooling properly. Seems to be blowing cold air out on th outside rather than inside.need instructions on troubleshooting
This is a reverse cycle (heating and cooling) model. It sounds like you have it in heating mode. Check the Panasonic website for an owners manual.
Jan 30, 2017 | Panasonic Heating & Cooling
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Why my mitsubishi air con blinking 6 times ?
that is only half the code you need the remote an lots more steps to troubleshoot that conditioner
here is some simple steps . but id get help on this.
http://www.daikin.com/products/ac/services/troubleshooting/
after that comes this step an its exacting
AstiquerMold Control Air con Specialist
in that page at the top is the command for your unit to ask it what code its tossing.
Jan 05, 2015 | Mitsubishi Heating & Cooling
Can a pro recommend a comperable replacement wall AC only-no heat?
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
Apr 09, 2014 | Heating & Cooling
Air con makes a loud wooshing noise then goes off. Red light flashes on unit. It's on the heating mode
Its the reversing valve shifting, it normal and you will hear it in the heating mode as well, you will hear it in the heating mode as well, during a defrost cycle.
Jul 04, 2011 | Heating & Cooling
My reverse cycle air con (Mitsubishi MSH 12RV) is not producing warm air (for use during cold weather). Which is likely the faulty part ?
Oct 30, 2009 | Heating & Cooling
What do the mode icons on remote control for Mitsubishi Air Con mean? Thank you.
Aug 01, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Fujitsu Reverse air con not blowing heat anymore
Reverse setting could need checking here sliding valve could have siezed. you would need a service Technition. your default setting is working fine so it needs to be checked on heating mode function.
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
